Clock Retainer Clips
Old Jun 14, 2009 | 04:07 PM
bmcnitt's Avatar
bmcnitt
Default Clock Retainer Clips
Does anyone have a picture or drawing of how they work? Mine are apparently missing. When I accelerate the whole clock starts to slide out. I am wondering how hard these clips are to install. Can you just take the little dial **** off the bottom of the clock and pull the whole thing out and put the clips in that way. Thanks in advance for any help you can give.
Old Jun 14, 2009 | 04:26 PM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
The clips slide over the studs with the ***** on the end. Each clock requires two clips. Virginia Vettes sells them for $2.95/ea
1-757-229-0011
Old Jun 14, 2009 | 04:33 PM
gscott's Avatar
gscott
You need to take the heater vents off and install behind the clock.
Gary
Old Jun 14, 2009 | 06:07 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Or you could do what the PO did to my car. He just used 2 small pieces of rubber hose that he pushed over the pins. It seems to work perfectly.
Old Jun 14, 2009 | 06:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
take the glove box out and you can see the back of the clock. the pas side is easy the driver side you need small hands. but it can be done after the radio side pannel is off
Old Jun 14, 2009 | 07:00 PM
midyearvette's Avatar
midyearvette
i have seen that also and it does work......
Old Jun 14, 2009 | 07:11 PM
stingrayl76's Avatar
stingrayl76
Does the whole clock slide out or is it just the bezel coming loose?
Here are the clips.
Old Jun 14, 2009 | 07:19 PM
66jack's Avatar
66jack
The whole clock comes out...
Old Jun 14, 2009 | 07:27 PM
stingrayl76
Jack,
Yep, if the clips are gone the whole clock comes out, but what I was trying to determine by my question is whether he's missing the clips or the bezel has come loose from the case making it appear that the whole clock is loose.
Dave
Old Jun 14, 2009 | 08:19 PM
landshark 454's Avatar
landshark 454
Removing the right side panel from beside the radio should allow you to access the back of the clock to install those clips. They just slide on.
Old Jun 15, 2009 | 09:07 AM
bmcnitt's Avatar
bmcnitt
Yeah, the whole clock slides out, very annoying. Should have fixed it a long time ago.
Old Jun 15, 2009 | 11:52 AM
DZVette's Avatar
DZVette
Here ya go.
Dave Z
Old Jun 15, 2009 | 08:16 PM
bmcnitt's Avatar
bmcnitt
Originally Posted by DZVette
Here ya go.
Dave Z
Fantastic. thanks.
Old Jun 16, 2009 | 05:48 PM
ragtopman's Avatar
ragtopman
St. Jude Donor '10-'11
....and if you need them, I have a pair. FREE
To Clock Retainer Clips
