Harbor Freight = Candy Store
as a retired mechanic i'm a snap-on guy with snap-on boxes full of snap-on tools, but have been going to the local harbor freight store all the time since i retired. while they are not snap-on but mostly cheap (and i mean cheap $ wise) the harbor freight stuff holds up very well. i get their fliers and always buy stuff on sale. you can biuld a profesional shop at your home on the cheap!!
two examples:
i bought one of their 60 gal. 7HP cambelhousfield compressors on sale for $399 5 years ago-220 volts. i have painted several cars with it, run air tools with it about 4 or 5 days a week, it runs my sanblaster (a real air hog-also from HF), it also runs my bead blaster (also from HF). in 5 years all i have touched is the petcock on the bottom af the tank to drain the water...
i did buy a quart of oil last year to do an oil change on the air pump, maybe i will do that next year...
i bought their 4 1/2 angle grinders
on sale for $14.99. i thought "note to self, if this grinder lasts for only 30 hours it only costed 50 cents an hour. this was 4 years ago, restored 3 old cars and it has about 200 hours on it and though i have worn several grinding wheels, the grinder works like the day i bought it.
we even used the 3" X21" belt sander i bought from HF on sale for $19.99 on astrodokks car (no, it was used on the stamp pad...
)later...
Much the same but bigger selection and appears to be a better quality of Chinese junk
BTW - just had an air tool quick connector fail from HF - running 100 PSI. Cracked across the Made in China stamp on the female nut.....
I have noticed that their hose clamps are worthless and just the smallest amount of pressure usually causes them to fail.
Doug
I believe they have an additional 15% off your entire purchase this w/e.
They also have a battery tender knockoff for around $7.00...anyone tried one ? I'm thinking of it for the riding mower.
Believe it or not, I have used their trickle charger for over four years on my cars and they work just fine.The price is scarey cheap (on sale at times for $5) but todate no problems. Had one on a battery sitting on a shelf for over two years untouched. Car fired right up .
. i have one for every battery.i used to have to buy a new battery for my harley and lawn tractor every spring, with those HF battery tenders i now have 3 years on the harley battery and 2 years on the lawn tractor battery, both start great.
I have one of them on my riding mower. I keep it hooked up when I'm not using it. The battery is 6 years old and it still starts right up every time so it must be working.
Jim
Jim
Go to their web site. There are 38 stores in Ca.
They've been on our '64 three years and our '01 for two years. No problems at all.Greg
They have two web sits http://www.harborfreight.com/ and
http://www.harborfreightusa.com/ It pays to compare what's on sale because the sites have different prices. My local store will match the internet price so it it's worth doing the homework.
