Firewall padding / insulation question
I am getting ready to replace the firewall sound deadener / insulation in my 65 vert. Curious if anyone has any tips on doing this or pictures before and after? I was interested in what exactly has to be removed to reinstall these pieces fo insulation. I already have my Gauge Cluster, Glove Box, and Heater unit removed from the car. Any help is appreciated.
Thanks,
Matt
You will need to make a tool for installing the lower insulation rubber retainers. They are a bit of a PITA to work with. Make sure you put some sort of lube on them, that will not eat rubber, and then use a screwdriver with the tip cut off to push them into place.
You might need to remove the radio, speaker, and defrost duct work, but i dont recall 100 percent
Original thread here:
http://forums.corvetteforum.com/show....php?t=1860653
Dave Z
