Adding transistor ignition.......
Old Aug 9, 2009 | 08:44 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Adding transistor ignition.......
I would like to to add a factory TI system to my 67. Already have an amplifier and a distributor. What else is needed and what is involved in making the switch?
Thanks,
Rex
Old Aug 9, 2009 | 09:11 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default T/i conversion
Thanks,
Rex
I did mine many years ago. You have 2/3 of the parts necessary. You now need the harness. They are available from the harness reproducers such as Lectric Limited. If I remember correctly, they come with the connectors needed for the conversion. You have to crimp on or solder 3 connectors onto the existing harness in the car, remove the ballast resistor, and just hook everything up. The 67 assembly manual has the procedure listed in section K-66.
RON
P.S. The factory filled in the ballast resistor mounting hole with a piece of Dum-Dum.
Old Aug 9, 2009 | 09:28 PM
chrislyn's Avatar
chrislyn
Default transistor ignition
Take a look at this site ,it has alot of info on this subject. Good luck
http://tispecialty.com/
Old Aug 9, 2009 | 11:09 PM
67L36Driver's Avatar
67L36Driver
You also need a TI coil. Points type coil won't work.
Old Aug 9, 2009 | 11:35 PM
rongold's Avatar
rongold
Default Ti conversion
67L36Driver is right--I forgot about that. Repro TI coils are readily available from many sources.
RON
Old Aug 10, 2009 | 01:40 PM
Joel 67's Avatar
Joel 67
Does anyone know what the ohm measurements should be on the TI coil? I have a repro coil but I am getting some strange resistance measurements, but they are different from my other points coils.
Old Aug 10, 2009 | 04:02 PM
67L36Driver
Primary resistance -----------.38-.51 ohm
Secondary resistance---------8200-12,400 ohm
from the '67 CSM.
My cheapo Sears multimeter cannot get an accurate read on the primary.
Old Aug 10, 2009 | 05:41 PM
robert miller's Avatar
robert miller
nice web site.
Old Aug 11, 2009 | 11:28 AM
Joel 67's Avatar
Joel 67
from the '67 CSM.
Thanks, that could be my issue as well!
To Adding transistor ignition.......
