C1 firewall grommets
I do not have the aim manual in front of me so I cannot look at the AIM manual to reference. I do own the manual though a picture is more helpful.
Thanks!
Okay, thanks!
I don't remember if I posted here or on NCRS. I'll try to find the drawings and post them tommorrow.
Larry
This is a little hard to read. If anybody needs the original, Email me.
I have another that shows the names on the drawing and also has the
holes for the insultion retainers in red.
A Heater Hose
B Heater Hose
C Insulation fastener
D Tach cable single larger hole
E Hood Latch two small oval shaped
F Insulation fastener
G Insulation fastener
H Heater flapper cable No grommet use Dum Dum
I Insulation fastener
J Insulation fastener
K Ignition harness and radio ground
L Ballast resister screw
M holes that where in my firewall?
N holes that where in my firewall?
R Oil gauge and Wiper cable Grommet has one small and one large hole
S Speedometer single hole large
T Windshield washer two holes lrge and sml
U Insulation fastener
V Insulation fastener
W Screw from inside for fuse block
X Main wire harness
Y Insulation fastener
Z Insulation fastener
Larry
A Heater Hose
B Heater Hose
X Main wire harness
Larry
Should I first, put the grommets into the firewall before the firewall insulator? It looks like I should do this prior to installing the insulator though I just want to make sure.
For example - if you install a grommet for the speedo cable, you'll play hell getting the cable to go through the grommet. But if you get the cable through the firewall, then put the split grommet around the cable and push it into the firewall you may have better luck.
I use a little Sil Glyde (NAPA) (something MagicV8 turned me on to) on the bayonet part of the grommet and it makes them go in fairly easily. Don't get carried away as they can become slippery. Also, when you put in the firewall insulation, make one of these tools that bigearl65 posted about a while back:
http://forums.corvetteforum.com/c1-a...cool-tool.html
I just put in the last piece of insulation the other night and all went in quite easily. Lubed the points with Sil Glyde as well. For whatever, reason, the plugs were a lot easier to install in the our '60 than they were with the '65.
Good luck.
Dave Z
