Make sure you have 12+ volts and a good ground. If they don't blow then, they are likely burned out/broken.
If they are correct for your car, there are a few folks out there that do repairs/restorations. Not cheap, but they can be fixed.
Part numbers and dates are on the horn body, you just have to look carefully......very small stampings and parts of the various numbers may be missing/obscured.
If they won't blow, squirt a shot of WD40 into them and let them sit for awhile. If it makes them work great, if not, no damage done. I did it to a pair that sat for 25 years, they work just fine now.
ahhh...WD40. I have like 6 cans of the stuff laying around. First I've heard on a horn fix. I'll try it on mine, one is dead, one is weak. I assume you have to kind of spin it around to work it down into the trumpet?
BTW, You can fix about 50% of "barn find" car problems with judicious use of WD40, 3 in 1 oil, and grease.
You should be able to bring the weak one back. Use the WD and turn the adjusting screw a bit.
Joe, If you can't fix them, and want to replace them with something that is effective (loud) and inexpensive, go to the auto recycler (junkyard) and look for a pair of horns from any large Buick, Caddy Pont. from the 60's/70's. Make sure you test them before you leave. They had loud horns. I put a pair on my car, only had to bend the bracket a small amount and they fit in the original location. Yes they do get the persons attention who is on the cell phone. Dennis
If the WD-40 thing doesn't work (and it usually doesn't), and the horns are original 487-488's, send them to Ron Goralski, byegonevette@comcast.net; best midyear horn restorer out there, charges about half what the other "experts" do, does flawless work.
or you can do it your self LIC sells the repair kit. its easy to do and takes less then a half hour. but Ron is the man if you don't feel up to it
