Can some one tell me what this is?
283 cid engine numbers are 4 turned sideways then GM 3849852 on the left side and on the right side 3114 or 8114 can't tell for sure. What did this 283 come out of and what year is it? Thanks to all that know and can help.
Very common '58-'67 passenger car and truck 283 block, never used in Corvettes; that one was cast in either March or August of 1964. Anything stamped on the front pad?
John, yes it is hard to read because the powder coated the block and heads and intake but here is what is on the stamp pad.
F02I2JH thanks for your help. It has double hump heads on it,
