Dash info
Old Nov 7, 2009 | 09:23 PM
JimSR's Avatar
JimSR
Default Dash info
I have my gauge cluster all stripped out. Getting ready to strip of paint question can I use any kind of paint stripper without harming the cluster. Also were can I find sliver bezel paint.
As always Thanks JIM
Old Nov 7, 2009 | 09:36 PM
Early 63's Avatar
Early 63
I used a mild paint stripper from Walmart and the cluster paint I found at Corvette Central. Part # 102011. Turned out great.
Old Nov 8, 2009 | 03:19 PM
Russ T Gate's Avatar
Russ T Gate
I'm about to do mine and will try lacquer thinner or actone to remove the paint, however all the gauges will be remove before I try this approach.
Let me know what works for you.
Good luck
Russ
Old Nov 8, 2009 | 05:11 PM
hzz's Avatar
hzz
Laquer thinner works well for removing the paint, assuming you have all the gauges out of the cluster.
As for silver paint, for the bezels I just sprayed the whole cluster black, then used my finger with a bit of laquer thinner on it to wipe the black off the edges of the bezels.
To Dash info
