1961 PCV conversion
I hope that it helps you identify the issue.
Paul
PS. I also checked the JG for those spinners; depends if they have the correct bluish tint and not the yellowish tint of the repros.
I like your installation, BUT I wonder (over time) if oil will accumulate in the lower hose rather than in the separator. It looks like any oil would have to make a serious uphill climb to the separator. Just a thought to consider, not criticism. Clever solution, though.
I worried about blow-by exhaust from my draft tube, also. What I did was to thread a brass fitting into the draft tube that I shortened and squared off about 3 inches shorter than normal length. The fitting threaded into the end of the draft tube by friction and accepted a 3/4-inch heater hose on one end that I extended about 2 inches below the frame. I cut the hose at a 45 degree angle to create a draw that assists the expulsion of vapors when the car is moving forward. So far, no greasy film on the underside of the car.
Good luck and Merry Christmas!!
Mark
The "fix" was to remove the hose from the air intake (plug the port), drop the hose over by the battery and into a vapor separator. Then, another length of hose below the engine.
The result is no more fouling of the oxygen sensor and air cleaner element, less oil consumption and I empty the separator from time/time and pour the trapped oil back in the engine
I'll fix the engine when I feel like it.
