question, what is the lowest temp that a engine should run to burn off
all the gases or what have you in the oil. i know you should run the engine a bit and not just an idle to get the fluids to the right temp?
to me 160 sounds too low. jim
a lot of opinions on this but 180-205 seems to be consensus of what i have read....im sure there is a time element in there also but i usually go through two t stat cycles before i shut it down while in cold storage and i run it once a month and leave the battery disconnected in the mean time....marine engines run cooler water temps but because they are under such a constant moderate to heavy load, the combustion temps are high enough to ward off any sludge buildup and they run under ideal pure air conditions, there is hardly any dirt on the water....this is why a by pass to the pump is so important for faster warm ups and consistent temps.... i think the op has a leaky stat. ..the card board works but should be removed in warmer weather as stated earlier.....
Ya, this isn't the first time someone brought up marine engines to prove their point.
I usually dont have the desire to go through all the reasons why they are different. Thanks for making the effort.
A V8 engine burns a LOT of fuel and generates a LOT of heat ending up in the coolant. If the therm is operating properly AND is immersed in the coolant flow the block will heat up till the therm starts to open at it's rated temp. A piddly size heater core won't overcool a V8!
When the therm is closed, blocking the rad should not really make much difference. Water flow should be close to zero.
It's been stated before that a 180 stat is optimum for performance and keeping the oil temp in its effective and safe range.
I know this may be a little difficult to believe for some folks, but I know it for a fact. I had a friend with a small Chevy pickup that wouldn't heat up in the wintertime. You could pull the cap off the radiator and stick your finger in the coolant, it was only warm.
He tried everything to get it warmed up, including totally blocking the radiator with cardboard, changed the thermostat 2 or 3 times, nothing worked. This went on for 2-3 years, like to have froze in the wintertime. I saw him a couple of years later, he told me that a GM parts man told him to put in a GM thermostat. Naturally, he didn't believe the GM thermostat at 3 to 4 times the price of various local FLAPS thermostats would make a difference. Wrong!! Voila! Problem cured, warmed up as it should have and neither he nor I had an explanation for why it worked when the others wouldn't.
I still don't know why it worked, but I don't argue with success.
the new tstat didnt leak. it is as simple as that. i had to use some wire and jbweld to fill in the slack in the intake.
you might have the wrong cap,search fan clutch adjustment ,you loosen the spring on the front a half a turn. I went thru that problem last year it seems much better now. try it .
Could be, I don't know. I didn't see the 3-4 FLAPS thermostats that he had tried. Still couldn't believe that the coolant wouldn't heat up with the radiator airflow totally blocked.
1 thing i noticed, the tstat housing makers, at least 1 anyway have got the message.
a housing i got 15 yrs ago had a THIN O-ring that caused the internal leak.
Got a new housing and it has a real THICK oring that looks to solve the problem-doesnt allow up/dn movement that lets water pass by the t'stat.
Anyone can check for a leak:
1. Cold start
2. drive 2 miles
3. grab upper rad hose at rad. Should be COLD! if it is warm, tstat is leaking, or some dingbat drilled holes in it
Some good suggestions, thanks to everyone who has offered their ideas. I will pull the new T-stat and double check it's operation and for internal leaks as well. That sounds promising. I'll also look at the fan clutch adjustment too. Don't think the car will be out on the road again till spring now with the 18 inches of snow we got last night (and all the salt ) but I will try to see if I can get the temps up at idle at least. Pilot Dan
