Gas Additives
Old Jan 5, 2010 | 09:18 PM
  #41
MikeM's Avatar
MikeM
Originally Posted by LT1driver
listen to john Z and I can attest to what he says as I used 91 shell in my 435 and LT-1 with no ill effects or detonation. if you want to talk 435's pm me and I will give you a call next time I am in dallas and we can meet somewhere. for gas just get some racing fuel to add to your local stuff and you can sleep well at night.
I don't understand. Your 435 runs well on 91 octane so why should the OP put racing gas in his 435 and call it a day?.
Something's wrong with your picture here isn't it?
Old Jan 5, 2010 | 11:24 PM
  #42
Vogie's Avatar
Vogie
I think the OP asked about different additives and how well they worked, not whether to use them or not. The thread drifted to where we are now.
Old Jan 5, 2010 | 11:52 PM
  #43
Glasshole's Avatar
Glasshole
We can get 94 octane up here in Canuckland at our local Chevron stations. No 94 down south??
Bob
Old Jan 6, 2010 | 07:35 AM
  #44
MikeM's Avatar
MikeM
Here is what the OP said he is trying to accomplish with the additives:
"trying to avoid engine knock and burning up valve guides because the engine is original and supposed to have leaded gas and higher octane than I can buy".
Since many owners have no problem running their stock spec 435 on commonly available pump gas, it would seem to me the appropriate action would be to find out what was wrong with the the OP's engine rather than just "add racing gas" (or additives) and put up with the expense and inconvenience don't you think?
Or do you think maybe the OP just bought this car, isn't sure whether he has a problem or not and is just reacting to something he heard about 435's on the internet?
Maybe it's the latter but it's not really clear.
Old Jan 6, 2010 | 09:29 AM
  #45
65tripleblack's Avatar
65tripleblack
Mr. Morgan wanted to hear someone tell him to add race fuel. After that "solution" was suggested, Mr. Morgan has buttoned up.
It is fairly well established that SHP BBC are much closer to the "ragged edge" of detonation as originally "out of the box" than SHP SBC. It doesn't take a whole helluva lot to induce detonation in a stock L71/L72/L78 running on 93 PON.
That is the reason why I asked the OP "how badly does it detonate" in post #24. I was trying to have the OP adopt the possibility of "tweaking" the engine, or perhaps addressing what probably amount to a myriad of minor remedies before resorting to fuel additives, etc. A simple cleaning of carbon deposits from the chambers, colder plugs, bigger primary jets, retarded timing, etc etc might be enough to resolve the issue.
Old Jan 6, 2010 | 10:08 AM
  #46
Powershift's Avatar
Powershift
Bob
Bob:
How is your gas octane measured?? Research, Motor, or the average of the two (R+M)/2....also known as PON or Pump Octane Number.
Some areas outside the USA use different measurements, which can confuse comparisons. I know Australia and Europe use a different standard. Not certain about your part of Canada.
Larry
Old Jan 6, 2010 | 10:10 AM
  #47
midyearvette's Avatar
midyearvette
Bob
octane goes up the farther north you go......global warming!
Old Jan 6, 2010 | 10:22 AM
  #48
Mike Ward's Avatar
Mike Ward
Originally Posted by Powershift
Bob:
Larry
Our octane is measured the same here as in the US. 94 is available, I'm just not sure why.
Actually, yes I do know why. There's a long line up of kids with f*rt pipe equipped rice rockets just waiting to try it out. Word on the street is that high octane adds lots of HP. History repeats itself.
Old Jan 6, 2010 | 10:58 AM
  #49
MikeM's Avatar
MikeM
I'd suggest you offered the right approach but since the OP has disappeared, I think it's safe to assume you are correct that he was looking for an answer he wanted to hear.
Your line of thinking was the same reason I asked what he was trying to "fix" in the second post in this thread.
I often wonder how many new Corvette owners of old Corvettes even know what "spark knock" even sounds like since there have been knock sensors installed on most electronically controlled engines for the last thirty years and lots of drivers have never even heard the sound.
Old Jan 6, 2010 | 12:17 PM
  #50
wmf62's Avatar
wmf62
St. Jude Donor '07
hell. my new/old corvette knocks even with a knock sensor... electronics aren't the answer to everything
Bill
Old Jan 6, 2010 | 12:30 PM
  #51
MikeM's Avatar
MikeM
Bill
Sumpthin's broke!
Old Jan 7, 2010 | 12:04 AM
  #52
Vogie's Avatar
Vogie
Originally Posted by RobMorgan
I recently purchased a 67 w/ 427/435HP original engine. I am wondering what success people have had with different gas additives. So far, I have been trying Gunk Lead additive which is all I have been able to find and a couple different Octane boosters.
Sorry guys. I must have misunderstood his question. It is true that he expanded it with subsequent posts so I stand corrected.
