Another stamp pad
Old Feb 11, 2010 | 11:47 AM
Kent in KC's Avatar
Kent in KC
Default Another stamp pad
Would appreciate opinions on this stamp pad from my '63:
Thanks in advance...
Old Feb 11, 2010 | 12:14 PM
shemp's Avatar
shemp
I'm no expert but it looks to have been restamped to me. I see just above the 0 and 3 in the vin faint numbers that look like a 2 and 8.
Just my opinion.
Shemp
Old Feb 11, 2010 | 12:16 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
agree with Shemp - am seeing numbers in the background - really evident if you blow the pix up
Old Feb 11, 2010 | 12:25 PM
shemp's Avatar
shemp
MDZ 06 I guess your snowed in too. Shemp
Old Feb 11, 2010 | 02:38 PM
Kensmith's Avatar
Kensmith
Stamp looks ok but the pad looks messed with. I would guess a re-stamp due to the pad surface.
Old Feb 11, 2010 | 02:40 PM
mdz06vetter
Shemp,
52 inches on the ground from the last two snow falls - thank the good Lord for a snow blower, as I was able to stay ahead of it - problem was then getting out of the sub-division where I live
Old Feb 11, 2010 | 03:51 PM
65 vette dude's Avatar
65 vette dude
The surface has too many, fresh looking, horizontal sanding marks. Still, it may not be a re-stamp. Could be somebody got overly aggressive trying to clean up an original pad.
Old Feb 11, 2010 | 04:27 PM
shemp's Avatar
shemp
But what about the numbers you see? Shemp
Old Feb 11, 2010 | 04:58 PM
Mike Ward's Avatar
Mike Ward
Looks like the numbers were stamped AFTER the surface was messed with.
Old Feb 11, 2010 | 05:34 PM
65 vette dude
On my display,I do see a little bit of something between the 0 and the 3, that's kinda half moon shaped. It certainly could be whats left of old numbers. Mike has got a good point, it does look like the stamping was done after the new broach marks. Probably a re-stamp.
Old Feb 11, 2010 | 05:42 PM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
It looks like a restamp but I did not stay at a Holiday Inn last night.
Old Feb 11, 2010 | 07:00 PM
63split63's Avatar
63split63
Default Do you really want to know ?
Hi, If you really want to know you can send pictures of the pad , the trim tag, the ser # plate, casting # on the block and block date to Al Grenning . For $ 200.00 ( last time I checked ) he will study them and give you his opinion.
It could possibly be a factory grind out and re-stamp . There are lots of them out there .
Regards Bill Purdy
Old Feb 11, 2010 | 08:12 PM
1-2-b-67L89's Avatar
1-2-b-67L89
Regards Bill Purdy
Believe Bill they usually used a type of grinder to grind out prior to re-stamp at the factory. They did not seem too keen on making it look real pretty . The ops pad is not original (broach marks?) and seems fairly obvious to many of us novices that it "just ain't right." Good info to know about Mr. Grenning if someone wanted to go that route.
Chick
Old Feb 11, 2010 | 11:05 PM
Tempus_Fugit's Avatar
Tempus_Fugit
I need to change jobs.
Regards Bill Purdy
Old Feb 12, 2010 | 10:33 AM
JohnZ's Avatar
JohnZ
If so, you also need to take 12,000 high-resolution macro close-ups of midyear stamp pads.
Old Feb 12, 2010 | 04:41 PM
Joel 67's Avatar
Joel 67
John, are all of those unique pads?
Old Feb 12, 2010 | 04:47 PM
63split63's Avatar
63split63
Default To Chick
Hi Chick, I have been told that all they used to do the grind out at the factory was a hand file . That may explain why they didn't always get all of the origonal stamp out .
Bill Purdy
To Another stamp pad
Old Feb 12, 2010 | 10:32 PM
Kent in KC's Avatar
Kent in KC
Default Thanks...
appreciate everyone who took time to reply.
Old Feb 13, 2010 | 09:47 AM
John BX NY's Avatar
John BX NY
When we toured the flint engine plant in 1991 they showed how they fixed a boo-boo. They ground it out with a 4" 36 grit sanding disc mounted to an air grinder
Old Feb 13, 2010 | 10:36 AM
Kent in KC's Avatar
Kent in KC
Default That's my story and I'm stickin' to it!
Seriously, I appreciate all the resposes.
