Gas Mileage with the 5 speed
#41
Overdrives kill solid roller motors
While the gas millage that goes with a 5 speed with overdrive makes things far more livable the .6 series overdrive gear ratios are a death prescription for solid roller valve-trains.
This is due to the reduced oil pressure incurred with the extended low rpm cruising that goes hand in hand with a .6 overdrive ratio.
Solid roller motors run great at medium and high RPM but it is the low RPM at idle or stop and go traffic that have always been the problem for solid roller lifter longevity........ Consequently extended low rpm cruising with an overdrive can be a death sentence for an expensive custom motor all for the sake of getting better gas millage....
Doug
Doug
#43
Did I ever say the driveshaft wasn't turning ? I'm a little smarter than that folks. As I said that is a custom, balanced driveshaft and even so I would still expect vibrations to be exaggerated under load and they were not.
I have about 35lbs oil pressure at idle (850 RPM)....at 1600 RPM I prob have 45lb+ (I have a dyno sheet to back these numbers up). I doubt my engine's top end is going to be 'oil-starved' at low RPM cruising...
(Oh, and I have solid lifters but not roller lifters -- original motor).
I also am not concerned about gas mileage (why does this keep coming up?)....I wanted lower RPM cruising to keep from thrashing my motor to death at 75MPH...
ANYWAY....turns out I had a severely bent right front rim. I mean 1/2"-3/4" wobble on the tire balancing machine. All the d@mn construction around here I guess I nailed something and never knew it.
I swapped the bent rim with the spare tire rim and with all newly balanced wheels/tires my vibration is gone!
However I am now in the market for an original, straight rim with the 3 'nubs' to hold a hubcap...if anybody wants to unload one!
#44
Shurshot was talking about a solid ROLLER cam.........
Glad you found your problem (and easy to fix.....not necessarily cheap, but still easy).
John
#45
St. Jude Donor '07
there is no way on God's green earth that you could have bent a wheel that badly and not known what you hit..
Bill
#47
Seems there is a pretty constant controversy with overdrive vibration in these Tremecs
Did yours come with "their driveshaft?" Check length and balance... A touch to short in the shaft will "out of center" at the higher rotational velocity encountered as speed increases
I've seem this enough on other forums to say the problem may be internal... Hmmm Anybody else?
#48
I only did a short high speed run (coming home from the tire shop) and there was no more problem...I may get out some today for a longer check out.
I am amazed that nobody has brought up bellhousing run out as a source of vibrations....the TKO vendors stress this over any other issue and you have to show that the initial installation reading was within specs if you get warranty work done in most cases.
BILL - I don't know what to tell you. I saw how badly the rim was bent with my own eyeballs and I am a very attentive driver. I don't remember what I hit and worse yet, it had to be pretty recently or I would have been dealing with it sooner...
I might have run over one of those pokey Solstices that really old people drive around here and never thought any more about it.
#49
come on down!
Frank, just drive over to Lakeland, I have a FOUR nub rim for you. Try not to run over any Solstices, VW convertibles or other chick cars on the way over.....
#50
Haiti Relief Benefit Open Show
4:00 PM - 9:00 PM
Hosted by the Lord's House, and held at the AutoZone store, 1726 South Highway 27. 100% of the proceeds from this show will benefit Haiti Relief. All cars and trucks welcome, judging begins at 7:00 PM. There's games, raffles, and food and beverage will be available. Registration fee is $15. For more info, call Debbie at (352) 217-9149.
and dinner will be on me!
#51
Problem was definitely the bent right front rim...took a hike this morning on the turnpike and from 60-85 MPH the car is actually 'glassy' riding....very pleased that it turned out to be a simple fix... Also the steering is decent now...I was drifting all over before but didn't know if it was the high winds or the car!
#53
I totally agree. I am always amazed at the extent to which people will strive for gas mileage, especially in specialty cars like older Corvettes. They are what they are. I won't even begin to disucss the cost/benefit analysis either.
I used to ice race a Mazda GTX (turbo/AWD). That car, which was racing at WOT most of the time, got in the neighborhood of 4.2 mpg. A C1/C2 at 12 mpg seemed like econo mileage after that.
#54
#55
Its hard to buy that tho...this shop took better car of the car than anywhere else I've been....and I have a habit of showing up unexpectedly to check on progress and see how my car is cared for.
On the flip side, I can't accept the wheel was that way for any length of time because I'm too **** about the car not to have noticed the deterioration of the ride quality.
Picked up an angle gauge yesterday at Home Depot and will measure the driveshaft angle just to be persnickety ... not out of any real need to solve a problem.
#56
We are glad everything is smooooooth...
se ya out on the turnpike
#57
FWIW, One thing not mentioned is the very solid front engine and trans. mounting system in the C1's. That tight mounting method doesn't allow for much engine movement absorption like the C2's and up can. The low RPM's below the "sweet spots" of the various engine set-ups can cause any slight engine roughness to be transmitted into the entire car at each engine's given rough spot - as it transitions from basically an idle speed in 5th. gear at 60 mph., ie. lugging, to a useable power level at it revs further. Just a thought.
#58
ALSO - now that I drive at higher speeds routinely I'm running more air pressure in my skinny radials and I'm sure that contributes to how the car feels screaming down the interstate.
#59
Driveshaft Angles
Well I measured three different times and its like this:
(A) Very end of Tailhousing: 2-1/2*
(B) Driveshaft: 3-1/2*
(C) Pinion Yoke (measured with socket on it): 2-1/2*
A-B = 1*
B-C = 1*
As far as I can determine with my old eyes and a $9 angle gauge the driveshaft is perfectly aligned...
A-B = 1*
B-C = 1*
