Shock recommendations requested?
Old Mar 27, 2010 | 02:49 PM
I-WANNA-C2's Avatar
I-WANNA-C2
Default Shock recommendations requested?
Anyone have any recommendations on a good shock for my C2? It will not be a canyon carver just a cruiser.
Thanks for your advice!
Old Mar 27, 2010 | 03:44 PM
Pilot Dan's Avatar
Pilot Dan
I've got a set of the Delco gas shocks in my 64 with the stock rear spring and like the ride just fine for cruising. Depending on what rear spring you use (stock, fiberglass, what tension ??) you will get a lot of varying answers. Check the threads, you will find quite a bit of info. Pilot Dan
Old Mar 27, 2010 | 04:35 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
I use the Edelbrock performers. They have a variable valve system that works very well. Tight in the turns, forgiving on the bumps.Easy on my fiberglass.
In my opinion KYB gives a harsh ride on everything I have had them on. No more for me.
Konis are great. But they are expensive and have to be removed to adjust.
Any conventional shock made by delco is crap. All my delcos blow within 30k. As in fluid leaking from the seals.They have always been the weak link in every GM car I have owned. You probably won't be putting tons of miles on it. So maybe that won't be a factor, if you choose Delcos.
Where you live plays a big part. When I lived on the family ranch and did a lot of highway driving into Houston. My brakes,shocks and tires would wear three times longer than when I live in town. 15k miles in the inner city is like 40-50k miles on the highway. My .02 cents.
Old Mar 27, 2010 | 05:30 PM
ditchdigger650's Avatar
ditchdigger650
Bilstein gas shocks
Old Mar 27, 2010 | 05:33 PM
Pilot Dan's Avatar
Pilot Dan
That's a huge over exaggeration!! I've been driving with them for a few years now and no problems at all. OP, it will depend on the type of driving you are going to do. If not performance driving, you should consider the Delco's for basic cruising. They are not too stiff and give a comfortable ride for highway and basic cruising in my opinion.
Old Mar 27, 2010 | 05:45 PM
MiguelsC2's Avatar
MiguelsC2
No exageration. Just relaying my experience. Use whatever makes you happy.
Old Mar 27, 2010 | 05:48 PM
MiguelsC2's Avatar
MiguelsC2
Originally Posted by ditchdigger650
Bilstein gas shocks
When GM used Bilsteins, they had a quality shock.
Old Mar 27, 2010 | 08:30 PM
Kensmith's Avatar
Kensmith
The QA-1 adjustable gives you 12 different settings.
Old Mar 27, 2010 | 08:55 PM
Godholio's Avatar
Godholio
Bilstein gas shocks
The Bilstein HDs were exactly what I was hoping for when I got them.
Old Mar 27, 2010 | 09:17 PM
Dennis Beck's Avatar
Dennis Beck
I have four of these on my '66 Coupe.
Dennis
Old Mar 27, 2010 | 10:27 PM
turbocat's Avatar
turbocat
Old Mar 27, 2010 | 11:11 PM
Doug C Young's Avatar
Doug C Young
I have just finished my buddies 63 split window. He put Koni Gas shocks on his car and painted them grey just like the originals. They work absolutely great.
Old Mar 27, 2010 | 11:27 PM
66BBCoupe's Avatar
66BBCoupe
2025 C3 ('68-'73) of the Year Winner - Unmodified
2023 C1 of the Year Winner - Modified
2021 C2 of the Year Winner - Unmodified
Bilstein Sports - I really like them on the C2
Old Mar 28, 2010 | 12:09 AM
65 vette dude's Avatar
65 vette dude
AC Delco Roadhandlers from the Parts Ladi,about $100. Perfect for cruisin....you will like them.
Old Mar 28, 2010 | 12:11 AM
Astrodokk's Avatar
Astrodokk
I bought Bilstein HD's for front and rear, but replaced them with Koni's which I've not driven on yet. The Bilsteins weren't as firm as I wanted, so they're available for anyone wanting to use Bilsteins. PM me. True the Koni's need to be removed to adjust, which could be a PIA. I have KYB's on my truck and they are sweet!
Old Mar 28, 2010 | 01:46 AM
MiguelsC2's Avatar
MiguelsC2
They would be my first and last choice. I just couldn't justify the cost for my driving needs.
Old Mar 28, 2010 | 02:59 AM
mechron's Avatar
mechron
Hi, I'm back too-->. Koni's are the best hands down. thats what all the top racers have run since the the late 60s (3 turns from stiff to super stiff makes any car solid) i run super Ds on several cars (no longer made), Dokk bought 4 Koni classics, he adjusted them to "almost" super stiff.... he wants to drag race again this year (thu s the new short block build, the new Isky cam install. he also likes auto-X, so he bought big sway bars, Koni's and those crazy track auto X tires.
DOKK, we assembled your short block and degreed in your new Isky roller cam (that was a pain do to a stupid dial indicator problem)
but the rest of the build wen't great
To Shock recommendations requested?
Old Mar 28, 2010 | 09:43 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
I started with Bilstein sports. Too harsh for me. Tried Konis. I really liked them but I like to play with the adjustments. Taking them off although not difficult a bit of a pain. I switched to Spax externally adjustable. 22 clicks of adjustment. I am very happy with them.
Old Mar 28, 2010 | 10:46 AM
midyearvette's Avatar
midyearvette
.......pricey to say the least but playing with the adjustments is cool and you can tailor the ride to suit, especially easy on the rears...jmo....bilsteins are great too but i removed them for the qa1's and im glad i did....
Old Mar 28, 2010 | 01:33 PM
woodsdesign's Avatar
woodsdesign
I put a set of Bilstein HD's on my 65 coupe and I couldn't believe the difference in the ride. Much better then the Monroe gas shocks I had on b/4
