C1 Chassis - missing bracket
Old Apr 10, 2010 | 10:21 AM
mickatbp's Avatar
mickatbp
arw57,
If you could give me the diameter of the section of the cable housing that sits in the bracket (will need to order a front cable) including the diameter of the 'narrowed' section I guess where the bracket bolt passes to lock the cable to the bracket. Then I can make the bracket. I have this bracket and others to wled back in place before I can send it to get grit blasted ready for paint.
Old Apr 10, 2010 | 05:32 PM
mickatbp's Avatar
mickatbp
Just remembered, I am still missing the spare tyre (you guys say 'tire') bracket that is welded to the rear crossmember - if someone has photos and dimensions for this bracket so I can fabricate would also be much appreciated.
Thanks, response and help so far has been fantastic.
Old Apr 11, 2010 | 09:56 AM
rich5962's Avatar
rich5962
This may help both of you guys. I have a 59 frame here and needed a break from yard work anyways.
Rich
album here:
http://s684.photobucket.com/albums/v...C1%20brackets/
Old Apr 11, 2010 | 10:15 AM
62Jeff's Avatar
62Jeff
Rich
Nice job Rich.
Old Apr 11, 2010 | 10:22 AM
rich5962's Avatar
rich5962
Thanks!
Anybody else need anything? I hate yard work.
