C2 Cluster light problem
Old Apr 12, 2010 | 09:46 PM
Hitch's Avatar
Hitch
Originally Posted by Geek's 65
Hushmat? Aluminum foil coated hushmat? Hmmmmm.
Yeah but that shouldn't be an issue.. But then again there is Murphy out there...
Dave
Old Apr 12, 2010 | 09:49 PM
Geek's 65's Avatar
Geek's 65
Dave
Yes he is. Alive and well - apparently living in Texan's car!!
Old Apr 12, 2010 | 10:07 PM
62Jeff's Avatar
62Jeff
I'm just glad it's not my 65 this time!
Old Apr 12, 2010 | 10:25 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Dave
There is a possibility that some hushmat is behind the fuse block. That could explain everything. When I was writing that quote. The hushmat rang a bell.Would also explain the tiny shock I felt. All of my chassis grounds are recent new and intact.
Old Apr 12, 2010 | 11:39 PM
MiguelsC2's Avatar
MiguelsC2
Well, I knew I would sleep better if I went and checked. Sure enough about a 1/4 inch of hushmat was under the left side of the fuse block. Took about two minutes to correct. No more gremlin.
Thanks to all!!
Old Apr 12, 2010 | 11:46 PM
62Jeff's Avatar
62Jeff
Thanks to all!!
to Geek and Hitch for that clever deduction!
Old Apr 12, 2010 | 11:48 PM
MiguelsC2's Avatar
MiguelsC2
