63 327 block code
Old Apr 13, 2010 | 07:30 PM
tach drive 61's Avatar
tach drive 61
Default 63 327 block code
any info on these #s CE4N on a 3959512 casting , I know it is a 327 and shows 250 HP I think the ce were warranty blocks
.would gm have shipped a replacment block without a cam shaft and timing chain installed ? years ago ??? any ideas please thanks ! what was the difference in the build between a 300 HP and 250 hp , heads ? cam ? would the pistons and crank have been different , some old school questions !!!
Old Apr 13, 2010 | 08:28 PM
robert miller's Avatar
robert miller
Someone just had a write up on the diff on the 250 and 300 hp motors. Look at doing a search on here.
Old Apr 13, 2010 | 08:39 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
I asked about my 300hp 512 engine awhile ago. Since that time I've had it rebuilt and it is a big journal engine. The info I received from the guys here can be found at the link below.
http://forums.corvetteforum.com/c1-a...rect-date.html Dave
Old Apr 13, 2010 | 08:52 PM
midyearvette's Avatar
midyearvette
from mortec....
618....327...68-69...2
3956618....350.....69....2 or 4
3956632....307.....69....2
3959512....327...62-67...2...Was also used for some "CE" replacement blocks
3959532....283...64......2...Used for some "CE" replacement blocks
3959538....327...........2...Chevy II recessed oil filter boss, Used for some Chevy II "CE" replacement blocks
3970
To 63 327 block code
