I have the opportunity to buy a 67 coupe from a friend...here is the configuration
427/390 hp tri power, automatic, power steering, power brakes, electric windows, air conditioning and every other option offered in 1967.Its all origional, numbers matching ,red with white stinger, restored in the early 80's and basically in storage since, he is second owner, car fully documented...1 or 19 configured this way...Any opinions on value would be appreciated
If a real tri power car it would be a 400hp, not a 390hp.
Who says it is one of 19? If it is fully documented, can you provide a photostatic copy of the tank sheet? That would help in determining value and authenticity.
Rick
What's he asking for it? There is so much that can change or add to the base value of a particular car especially one like above. #'s matching meaning having it's born with engine? Not sure of the 1 of 19 so it would be excellent to learn how this production # was obtained.
Maybe 1 of 19 in that configuration because its an automatic? Sounds like a great car, but how many people would order that car as an automatic? Maybe 19 people.
There were no tri power 390hp, only 400 (oval port heads) and 435 hp (rectangular port heads). How much documentation is "fully documented?" Tank sticker? Protecto Plate? Original bill of sale, etc.? It could be the difference between a 60k car and a 100k car. More info please.
I know of at least two other red 390 '67 coupes with Powerglides and white stingers. As was mentioned, no way of knowing how many of any option combos were built in '67.
The real question is How much do you think it's worth?
