Ford Logic
Old Apr 27, 2010 | 02:25 AM
oldskydog's Avatar
oldskydog
From the 56 and 57 passenger car specifications. Note use of the "Corvette Type Engine" in the specs.
http://chevy.oldcarmanualproject.com...ges/56058a.jpg
http://chevy.oldcarmanualproject.com...ages/57052.jpg
From a 57 sales brochure listing the 'Corvette Engine"
http://www.oldcarmanualproject.com/b...ages/57-01.JPG
Old Apr 27, 2010 | 07:35 AM
MikeM's Avatar
MikeM
Originally Posted by 60SnSC68
The 332 was an mostly and Edsel engine in '59. The FE acronym comes from Ford/Edsel, just a little trivia.
"FE" stood for Ford Engine. Ford and Edsel used the 332 and Edsel used a (unique to Edsel Ranger,Pacer)361 CI version of the 332. The bigger Edsels used a Lincoln engine.
Old Apr 27, 2010 | 07:39 AM
MikeM's Avatar
MikeM
Originally Posted by kerrmudgeon
56 Chevies ordered with 2X4 carbs and solid lifters came from the factory with aluminum Corvette valve covers, with C-O-R-V-E-T-T-E on them and staggered holes. 265 cu in, standard 3-sp only.
225 hp, 240 hp or both?
Old Apr 27, 2010 | 08:22 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Not sure I believe this at all.
In another of my automotive lives I was involved with Tri-Five Chebbies and I saw lots of dual quad '56 cars. Never, ever saw one in restored condition with aluminum valve covers.
Not sure it would have even been possible to use them; the air cleaners at the ends of the batwing were partially supported/stabilized by metal supports spot welded to special versions of the steel valve covers.
Jim
Old Apr 27, 2010 | 11:35 AM
slotcarken's Avatar
slotcarken
I wonder if some full-size cars were fitted with the Corvette valve covers
and air cleaners by the dealer, as a way to boost sales?
Old Apr 27, 2010 | 12:47 PM
MikeM's Avatar
MikeM
Lots of cars were dressed up that way by the owners back then.
Old Apr 27, 2010 | 03:50 PM
jim lockwood
Guilty, your Honor. I put a set of 9 fin covers on my five-seven back in the day. I'm sure it went 10 MPH faster, too.
Jim
Old Apr 27, 2010 | 04:38 PM
MikeM's Avatar
MikeM
The oldest parts book I have is a '61. One common valve cover services ALL '55-'59 pass car engines and '56-'59 Corvette with four barrel carb.
You can take that to mean the above engines had the steel valve covers in production.
Old Apr 27, 2010 | 08:28 PM
60SnSC68's Avatar
60SnSC68
The FE, Ford/Edsel, engine was first installed on the production line in the form of the 361ci in August, 1957 in the 1958 Pacer, and Ranger Edsel. These models were built on the Ford chassis. The first ford to receive the FE, was in November, 1957 in the form of the 352.
The “only” engine available in the above 1958 models was the FE 361 cubic inch.
All the Edsels used the torque rating # on the valve covers, not the cubic inch #.
The 1958 Big Car, (built on the mercury chassis), which was the Citation, and Corsair, received the Lincoln engine mentioned.
The 332 was not available in the Edsel until 1959, when dismal sales forced Ford to revamp the whole Edsel line.
Old Apr 28, 2010 | 06:57 AM
MikeM's Avatar
MikeM
The FE, Ford/Edsel,
You are one of the confused cast of thousands!
Do you know what FT means?
Old Apr 28, 2010 | 08:18 AM
ghoastrider1's Avatar
ghoastrider1
I thought FE stood for Fairlane Engine...was told that years ago. The Thunderbird with the 312 supercharged (paxton) started it all, along with the " Ford Interceptor" or" police Interceptor" usage.
Old Apr 28, 2010 | 09:24 AM
Mike Ward's Avatar
Mike Ward
Full of Trouble?
Old Apr 28, 2010 | 09:48 AM
  #33
MikeM's Avatar
MikeM
Originally Posted by ghoastrider1
I thought FE stood for Fairlane Engine...was told that years ago. The Thunderbird with the 312 supercharged (paxton) started it all,.....
You are.......... grossly incorrect!
Both counts.
The 1955 T-Bird 292 cubic inch engine had cast aluminum valve covers with the Thunderbird emblem on them.
Where do you think Chevrolet got the idea for the '56 Corvette valve covers the following year?
Old Apr 28, 2010 | 09:49 AM
  #34
MikeM's Avatar
MikeM
Originally Posted by Mike Ward
Full of Trouble?
You should probably head back over to the C3 forum before you get in over your head here.
Old Apr 28, 2010 | 10:25 AM
  #35
Mike Ward's Avatar
Mike Ward
Ahhhh go soak your head in your hot tub. The cold water will do you good
Old Apr 28, 2010 | 11:07 AM
  #36
MikeM's Avatar
MikeM
I bet mine will be working again before yours.
Old Apr 28, 2010 | 11:22 AM
  #37
60SnSC68's Avatar
60SnSC68
Default Confused Thousands
If you had laid a multimillion dollar egg like Ford did with the Edsel, You would purge all record of the name in association with the mega failure.
Ford did just that with the Edsel name. Only recently, in the last decade or so, has Ford even acknowledged the Edsel car. (Such as the Ford centennial.)
The “Ford Engine” name you refer to didn’t appear until after the demise of the Edsel. And the FT didn’t come along until the next decade.
To Ford Logic
Old Apr 28, 2010 | 11:54 AM
  #38
MikeM's Avatar
MikeM
A 250 million dollar egg I believe was the program cost.
The FE was used initially in Ford, Edsel, Mercury, Thunderbird and Ford truck. Maybe it should have been called FEMTT? Same as the big engine was called "MEL" for Mercury, Edsel and Lincoln. But wait, the MEL engine was also used in T-Bird. Maybe it should have been called MELT?
There was really nothing wrong with the Edsel that wasn't wrong with any other US car in the late 50's. It just came into a very crowded mid-sized car market during an economic downturn. There were other brands that disappeared at the same time. Packard, Hudson, Nash and the full size Studebaker.
Lot's of journalists poked fun at the styling but hey, look around at he competition in 1958. Most of the '58 cars on the market were butt ugly and loaded with chrome.
Old Apr 28, 2010 | 04:47 PM
  #39
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
FE stood for Ford/Edsel. The FT designation refers to Ford Truck and the MEL (Mercury/Edsel/Lincoln) were replaced by the 385 series engines. The MEL engines were 383,410, 430 & 462 cid that were offered in '58 and ended in '67. The '58 Edsel had, as an option, the 410.
Old Apr 28, 2010 | 05:26 PM
  #40
MikeM's Avatar
MikeM
Originally Posted by Dan Hampton
FE stood for Ford/Edsel. The FT designation refers to Ford Truck and the MEL (Mercury/Edsel/Lincoln) were the 385 series engines which were the 383,410, 430 & 462 cid that were offered in '58 and ended in '67. The '58 Edsel had, as an option, the 410.
Old wives tale on FE equal Ford/Edsel. FT stood for medium/heavy truck. Not light truck.
MEL did stand for Merc, Edsel and Lincoln. The the 385 series engines were the 429/460, not the ones you listed. 385 stood for the stroke of the engine (429)
We got away from the original question so I'm outa' here.
