just finished my borgeson ps conversion. all happy, ready for the test drive. Go for a short drive and - what gives, no power steering. just like manual. Ok, leave the vette in the driveway while I do other chores. Then I go to drive the vette back into the garage and "it works"! So I decide, ok, going to drive around the block, and by the time I get back home, its back to its manual self. I check all belts, hoses, etc, and all is in order. PS fluid is almost to the full level. What could it be????
Please help. What should I check?
just did mine 2 weeks ago, you need to turn the wheels from stop to stop a few times with tires off the ground and check the level of ps fluid, repeat after topping up the level a couple of times till the fluid level remains constant, did you use the recommended fluid?
I did bleed the system, but will try again. There was no recommendation on the ps fluid with the kit, just used standard ps fluid from Walmart. Should I be using something else?
Gary
How very strange, Gary. When we added power steering to my bride's track car, the system behaved similarly. The cause was the fluid overheating and the solution was to add an oil cooler to the system.
Her car sees conditions you couldn't possibly be duplicating by just driving around the block. But overheated fluid is sure what it sounds like.
Gary I run that box on 3 of my cars and have never experienced anything like that. I don't know if fluid makes a difference, but I always use a quality power steering specific fluid from the parts store.
This is happening when it is stone cold, so it couldn't be a heat issue. I'll try the GM fluid, but am doubtful its going to make any difference. I bled the system again by moving the steering wheel back and forth about 20 times - same thing.
I suspect your power steering pump pressure relief valve is stuck open. The hex nut that your pressure side hose is threaded into holds a spring and a valve, as I remember. If you took your pressure hose off and removed the big nut that it is screwed in to, as I remember it needing a one inch wrench, I suspect it has some foreign debris stuck under the valve.
The fittings on the hoses are unique, and only fit one way. The pressure hose on the pump routes to the fitting on the box furthest from the firewall, which is the larger of the 2 fittings. The fitting on the box closest to the firewall routes to the steering pump inlet nipple.
Gary, why not call the dealer/mfg. of which system you purchased and ask them what might be wrong. There is a good chance through experience that they have had customers run into this before and can supply a likable cause. It's worth a try
Lynn
Ok, I removed the nut, and the innards, and this is what I have
i'm not quite understanding how the fluid gets past the first fitting. There is a tiny filter at the bottom of the first fitting. I tried blowing into it, and nothing. I also tried loosening the small nut at this filter, but it wouldn't budge, and didn't want to force it. Anyone know if this is how it is supposed to be? Didn't come across any kind of debris. When you stay stuck open, the spring was forcing the first fitting into the second fitting, again not sure if this would be in the open position or not.
I just thought I should close off this thread and explain the final results. I went down to the local GM dealer, paid $8 qt for ps fluid, flushed the old stuff, added new stuff, and what do you know, it now works. I guess this is one of those times the extra $ was well worth it! Thanks all for your help. Will post a picture later of the car with the new 14" Grant steering wheel ($100)
