The "010" blocks can be quite good. Many were made with 4 bolt mains and many were made with high levels of tin and nickel which makes them very durable.
My memory of the "882" heads is that they are lightweight, low compression, "smog motor" heads that are prone to cracking if overheated. AFAIK they all have 1.94/1.50 valves.
Jim
Nope, not true. The 882 are not light wgt. (at least none that I have used or seen). A well known engine performance writer has published that they are light wgt., and the myth continues............ I have used them on a twin turbo'd boat (7.5 psi boost) with good effect (and if they were prone to cracking, that would of been the place to see it). And they came originally in both 1.94 and 2.02 intake valve sizes (my wife's 74 Z-28 LT1 engine came with the 2.02" valves and that engine is in my garage as I type, but they were fairly rare with the 2.02 intakes).
But I agree they are not "performance" heads due to the low compression / large compression chamber, but also due to the poor exhaust port design.
Note also that these heads used the Chevy induction hardened valve seats. Originally (early heads) they were prone to cracking around the seats. Chevy refined their technique, and by 74 the process was pretty good.
Plasticman
The 882 heads are probably OK, but they're not performance heads. They have 76cc combustion chambers, so if the engine has flat-top pistons, you're looking at probably 8.5:1 compression. Nice if you're building a beater to run on regular gas...but even then you could put on better heads that raise the CR a bit and still run regular.
My engine has a 010 350 and HAD 882 heads. The 882s are from the mid 70s when performance was a joke. They worked well enough, but nothing special.
I installed a pair of 65ish 461s, on that engine and it made a really sweet difference.
From: The problem is all inside your head she said to me.
Originally Posted by Dakuda
Have found an engine with rebuilt 338882 heads, is this a good combination ??
thanks, Rory
I's say good block choice bad head choice. Now if you have hood clearance a vortec 350 is a good starting point. I just built a motor using an 010 block. I'm testing it's durability now
