Temp sending unit question:
Old Jun 29, 2010 | 03:41 PM
vic z's Avatar
vic z
Default Temp sending unit question:
Driving the C2 around in the hot south Florida summer.The AC is on and getting stuck in traffic.Watching the temperature gauge slowly climbing to 230. Shut the AC off, roll down the widows. I get the car to the house and check out the hoses with the IR gun.Top hose showing 190 deg and bottom showing 165. The sending unit is way off.
Any pictures or ideas where you installed a variable resistor for the temperature sending unit ?
Old Jun 29, 2010 | 05:19 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Note that there is no resistor or resistor network that will provide wide range calibration accuracy of the temp gauge. After adding a resistor of any value, the gauge will be accurate at one and only one temperature.
For example, suppose you add series resistance of such a value that 180*F coolant temperature indicates 180*F on the gauge. At coolant temperatures above 180*F, the gauge will read lower than actual coolant temperature, giving you a false sense of security.
Jim
Old Jun 29, 2010 | 05:34 PM
x0000rgw's Avatar
x0000rgw
Default Resistor
I have been using a variable resistor for 10 years or more. I set it to
180 degrees when the IR gun showed 180. If the gauge gets higher than that by very much (say 200) then I know there is a problem. That's all you can tell with a resistor in line.
Just splice it in where the sending wire goes into the firewall. Use about 30 inch leads so you can get to it and adjust to match the IR gun
reading at the water outlet (while engine is normal operating temp).
Stuff the resistor behind the radio console.
I used a 0-100 ohm resistor from Radio Shack. Get a plastic covered
one that uses a small screw driver to adjust. One with a dial **** can
get bumped and lose the setting.
Ray
Old Jun 29, 2010 | 05:41 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Corvette Central sells an adjustable resistor (30 bucks) that you can install at the gauge on the dash between your wiring and the gauge. It's adjustable so you adjust it to your IR gun. I've installed one in my car and a friends car and they both work perfectly. And yes, it will go above your initial setting you make, so don't worry about false readings. I set mine at approx. 180 and it will climb if it idles in traffic, and I have checked it with the IR gun while it's hot and it gives the same reading as the gauge. My car will stumble when running hot also, and the gauge will verify it.
Old Jun 29, 2010 | 05:42 PM
GCD1962's Avatar
GCD1962
The easiest solution is to get another temp gauge and make a take on/take off mount somewhere in the car so you can see it, and, if necessry remove it when you want. The sending unit can either go in the head, or you can get an adapter that goes in a heater or radiator hose. The modern unit will be accurate and you can leave the origninal in the car for the nit pickers.
Old Jun 30, 2010 | 10:06 AM
CaveCreekChump's Avatar
CaveCreekChump
Default How about just getting the correct sending unit?
I am a simpleton, so I like simple solutions.
I had the same problem so I got a Duralast TU-5 at the AutoZone website and my gauge now reads accurately.
Old Jun 30, 2010 | 10:48 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
You got lucky. I bought four of them and water temp tested all four before installing. Best one was still reading 20+* too high. For lack of a better solution, I live with it. Dave
vic z's Avatar
vic z
Sorry Doug, I should have mentioned that this will be the third one that I installed.I just called the local Autozone and they had one Wells TU5 left. Will give it a go this evening.
Old Jun 30, 2010 | 11:39 AM
Donald #31176's Avatar
Donald #31176
The easiest solution is to get an original that is calibrated correctly. Mary Jo sells them.
www.vettegal.com
Old Jun 30, 2010 | 02:56 PM
Jims66's Avatar
Jims66
Look here: http://www.corvettespecialtiesofmd.com/faq/faq1.html
Old Jun 30, 2010 | 05:18 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I've heard that Mary Jo and Dewitt's sell calibrated (but expensive) sending units but folks have had trouble with those too it seems. You can use one of those little plastic rheostats with the screw driver adjustment and once its set dab some nail polish on the adjustment to keep it set...
Old Jun 30, 2010 | 06:52 PM
Geralds57's Avatar
Geralds57
Good luck, I tried that one too plus about 9 others and none of them worked correctly. I spent more than enough on those to buy the one from Corvette Central to begin with, but I was trying to get off cheap. Get the one from CC, and it's over.
Old Jun 30, 2010 | 10:16 PM
CaveCreekChump
Default I'm still a simpleton!
It took me a bunch of tries to find a sending unit that worked properly with my gauge. Then I used the same AutoZone Duralast TU-5 in the 454 in my '66 Impala with the same good results.
Obviously, this is a continuing source of frustration, and I hope everyone will report their results as they experiment with different possible solutions.
Old Jul 2, 2010 | 10:16 AM
vic z's Avatar
vic z
Well the third one is the charm !! Installed a Wells TU5 and the temp gauge is spot on. Sure is refreshing not having to keep looking at that temp gauge showing faulty readings. Thanks for the tip !
Old Jul 2, 2010 | 08:55 PM
CaveCreekChump
Congrats on your success!
The Corvette Specialties link that Jims66 included above makes a good point.There are probably millions of OK sending units screwed into engines in junkyards all across North America.
If the car or truck had a temp gauge, the sending unit may still be worth a try.
Old Jul 3, 2010 | 01:13 PM
JohnZ's Avatar
JohnZ
An original AC #1513321 sender is the best replacement, but you have to dig through 60's junkyard engines to find them. I got lucky with mine - it has a Standard ST-6 sender, and it's right on the money. Photo below shows the AC original on the left, and the Standard ST-6 on the right.
Old Feb 9, 2012 | 10:44 AM
57FIPG's Avatar
57FIPG
8th Gear
Quick question, it should be 12v at the sender wire ??
Old Feb 9, 2012 | 11:47 AM
Mike Geary's Avatar
Mike Geary
I used a trimpot to determine how much additional resistance was needed.
Then, just added 1/4 watt series resistors, which actually fit inside the cloth wire covering.
To Temp sending unit question:
