Replace valve seals
"Viton seals provide better sealing to keep oil out of combustion chambers for improved engine efficiency and performance"
http://www.jegs.com/i/Comp-Cams/249/...ductId=1122701
Good luck... GUSTO
Dennis
To confuse matters, some engines still came from the factory with the positive seals on both the intake and exhaust valves, but I believe that these were the cast iron heads only.
Note that umbrella seals are not really seals (as used on some Ford engines and sold aftermarket for Chevy engines) that slip over the valve stems above the guide boss, and float with the valve as it goes up / down. They do not seal to the guide boss (as a positive seal does), but prevent most of the oil splash / mist from going down the guide / stem. They are more effective than just the square cut "O" ring that seals the valve stem to the valve retainer. However, if running the inner valve springs (dampers), they may not float due to interference with the damper spring (must be sized correctly - like everything else).
In your case (if in doubt), I would run extra seals on the intakes only, be it positive or properly fitted umbrella seals (along with the "O" ring seals on both valves). You may see a puff of smoke at startup, but that is a minimal price to pay (vs. having to replace guides and valves due to a lack of lube). And if you do see a puff, it might mean that the "O" ring seals are not doing their job or that the guides / stems are worn.
Plasticman
