You're right that there's not enough information here, but that's compounded by giving incorrect troubleshooting advice.
I didn't give any advice except for the op to provide more information.
I don't think anyone has given bad advice. There are several instances of inappropriate advice for the problem because the sinners didn't correctly read the problem.
A little tip here. The OP didn't say ANYTHING about can clearance.
'66 coupe with 327. Crane electronic ignition. Accel coil and wires. Will only start with timing way advanced (25 deg) Will run ok set there but hesitates on acceleration. If I back the timing off to 10 deg it will idle rough and wont restart. Has a Holley 4160 non adjustable carb. Any ideas??
If you add a Finnegan pin to the non adjustable Holley 4160, you can convert it to an infinitely adjustable PM carburetor.
Also, did you check the flux capacitor in the Crane?
SokoOH is a logical, sokoban like puzzle game in which the player pushes boxes around a maze, viewed from above, and tries to put them in designated locations.
Troll is playing games. You all know who this sounds like.
pull the crane out and install an MSD system and distributer add a manually controlled timing module and you'll be trouble free....this is too much fun! we gotta keep it going....
