327 Wrong Date Code
Old Aug 29, 2010 | 09:34 PM
milano maroon's Avatar
milano maroon
Default 327 Wrong Date Code
So my car is a '65 coupe. I've owned it since the early seventies. Even though I bought it when it was relatively "young", it had a hard life when I got it. Engine numbers aren't original, don't know about the rest of it. It is a driver which I'm trying to make as nice as possible. Not necessarily original but I want it to look like it could be.
The engine in it now is from a '65 Chevelle, set up like a 350 h.p. (pistons, cam, intake, and 2.02 heads). But one of these days it will need an overhaul.
So finally here is my question - I have a chance to buy a '65 Corvette block and crank. March or April date code. My car was built in November or December. Since I will overhaul my engine someday is it worth spending the money and putting a Corvette block in, albeit the wrong date code. Block and crank would run probably $500 or so. One advantage would be I could take my time building the engine and still have a driver. Whether I rebuild the one I have or the other block I am leaning towards lowering the compression, probably 10 to 1.
What do you guys think? Any advice you can offer me?
Old Aug 30, 2010 | 08:26 AM
63split63's Avatar
63split63
Default Sounds Fair Enough
500 $ sounds like an OK price to me if the crank is good and the block is not alreay bored way over. I wouldn't put too much value on the date as you can't see it from above anyway .
Bill Purdy
Old Aug 30, 2010 | 10:51 AM
SplitmanC2's Avatar
SplitmanC2
Milano Maroon;
I have a 63- SW, that isn't original, alas it has a 1964 Corvette block.
When I checked out the numbers I saw that the only part that wasn't 63, is the block, it is an RE suffix -300 hp "64".
But what it does have correct is,-63 fuelie heads, Winters Alum intake, AFB 4 barrel, 63 exhaust manifolds, high RPM tach and ribbed valve covers all for a 340 horse motor, except the block.
It now looks like a 340 horse car and it is still ALL Corvette, even though the numbers don't match.
IMO, I would buy the block, if it's any good and it is a Corvette motor put it in and then it will be ALL Corvette again, just not numbers matching.
Just have fun with it.
Al.
Old Aug 30, 2010 | 10:53 AM
remotecontroller's Avatar
remotecontroller
Default engine block
Check out the following link - I bought an 870 block from this guy (went up and met him to pick it up and a nice guy) and all was what he said it was (and the price is right at $150). He has a September 64 block .030 over so you could get a date correct block. Not sure if the sept block is a short block or just a block, but give him a call to find out. Not sure if he would crate and ship for you, but seems like you could still have it delivered for a lot less that $500.
http://dallas.craigslist.org/dal/pts/1847976179.html
He has other 870 blocks if anyone is looking for one. All 870 blocks, 3 are 1963 blocks (A-21 & E-9 are standard bore, F-20 is .030 over) and the Sept 64 block mentioned above.
Also, I am not going to use the short block I bought from him after all if you want do discuss that short block. Date is Feb 18, 1965 and it is a Non-corvette Flint block (Impala or something). Currently at .030 but needs to go to .040 according to machine shop (block has been magged). Has a polished .010/.010 crank (with some water stains) and good rods according to the machine shop. Also has .030 pistons, but will need to replace once the block is bored to .040.
Anyway, hope this helps.
Ken
Old Aug 30, 2010 | 12:27 PM
Kensmith's Avatar
Kensmith
I went through this dilemma some time ago. Found the correct date code block and heads. I was going to just try and make it correct for the car but not a numbers matching fake. After investing in the heads and block, I checked into some prices for rebuilding, machining, parts, etc. I ended up selling it to another forum member and buying a 383 stroker crate motor 450/450 for about the same price to rebuild the 327/365. Since I didn't buy the car for investment purposes, I decided it would be more fun to have the stroker motor with a ton of torque and way more horsepower than I could get out of the 327. BUT, if I had a correct 327/365 running gear and correct everything I would probably have built the motor VS 383 stroker. Your car, your decision!
Old Aug 30, 2010 | 10:56 PM
milano maroon
Thanks everyone for the responses. I am leaning towards the idea of making it ALL corvette, regardless of the dates. I am going to pursue both of these leads and see what happens.
I agree, the crate motor would be nice and a lot of fun to drive, but frankly I am looking for something a little milder, easier to drive, and hopefully do OK with the pitiful gas and octane levels we have available these days. I must be getting old...
Old Aug 30, 2010 | 11:50 PM
LSUvetteguy's Avatar
LSUvetteguy
St. Jude Donor '10
Your car, your call. But for that money and just a little more effort you could make it all Corvette with numbers and date correct. M2C
Old Aug 31, 2010 | 10:19 AM
milano maroon
Are you suggesting I keep looking until I find the correct Month? Does it matter if the block I might find is a week or two AFTER mine was produced as long as the alpha date code is correct?
Old Aug 31, 2010 | 12:02 PM
JohnZ's Avatar
JohnZ
Depends what criteria you're trying to satisfy. If you want it "correct" from a judging perspective, the block casting date should be up to six months prior to the car's final assembly date (although 2-6 weeks is "typical").
Old Sep 2, 2010 | 05:53 PM
milano maroon
Thanks again for the information.
So I may have found a 870 block with a casting date code preceding my body build date by 2 weeks. I don't know the exact build date of the car but by my calculations it is about another 5 or 6 days later than the body build date.
Problem is - it has been decked (or at least the pad numbers have been removed). Any way to tell if this is a Corvette block?
Old Sep 3, 2010 | 02:55 PM
JohnZ's Avatar
JohnZ
Your VIN will establish the car's final assembly date, as will the body build date on the trim tag if it's a St. Louis body. St. Louis-bodied cars were produced off the line the day after the body build date on the trim tag.
With no pad stampings, that eliminates identifying it as a Corvette block; however, it can be identified as a Flint block (which were the only ones used in Corvettes) by the use of a single digit for the year in the block casting date code, and by the presence of a square-head 1/8" NPT plug in the block at 11 o'clock just above the timing cover. Tonawanda blocks used two digits for the year in the casting date code, and didn't have the plug.
Old Sep 3, 2010 | 03:57 PM
milano maroon
Thank you for the information John. My car has VIN 197437S115116. I don't have a way of checking but I calculated that coincided with a April 12 or so assembly date. Am I close?
The trim tag says the body build date is I6 which I think means April 6. DBut if I have a St. Louis body then that doesn't work out. My other tag says A2676 BODY. Does that mean anything?
So the 870 block I am looking at has a date code of C235 which I took to mean March 23 cast date. Does it also mean it is a Flint block since there is only a "5" in the code? Would all of these dates work and allow me to have a "correct" dated engine for my car?
So a Flint block could go in something besides a Corvette but a Corvette will only have a Flint block?
Thanks for your patience.
Old Sep 3, 2010 | 04:16 PM
1snake's Avatar
1snake
Your car was 326 cars after my 65 coupe. I have A2600 body built I1 (April 1st). My block was cast C 21 5. The block you are looking at is perfect for your car.
Jim
Old Sep 3, 2010 | 04:51 PM
VetteRed1965's Avatar
VetteRed1965
Jim
You can't get a block any better !
Old Sep 4, 2010 | 03:45 PM
JohnZ's Avatar
JohnZ
Your car was produced on April 15th, give or take a day or two; it has an A.O. Smith body (A2676 body number) which was built in Ionia, Michigan on April 6th.
That's a Flint block, and as others have noted, it's fine for your car.
Your question on Flint blocks and Corvettes is correct.
Old Sep 23, 2010 | 09:04 AM
milano maroon
The C235 date code block didn't work out. I have found a C155, about a week earlier I guess. Would that be a good choice or should I keep looking.
Old Sep 23, 2010 | 01:54 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Originally Posted by JohnZ
----------------------------------- and by the presence of a square-head 1/8" NPT plug in the block at 11 o'clock just above the timing cover. -----------------------------------
And then of course, there's the guys like me who drill and tap a passage in EVERY block I build that doesn't have the plugged hole up front. I do this as a matter of routine for whatever purpose, or, just put in a plug.
Here's an example of an oil filled motorcycle oil pressure that I put in my boat engine (420SB). This allows visualizing the oil pressure right off of the engine. Oh ya, I did the same thing to the Olds 455 in my Cutlass.
Tom Parsons
To 327 Wrong Date Code
Old Sep 23, 2010 | 01:55 PM
JohnZ's Avatar
JohnZ
That'll work fine.
Old Sep 23, 2010 | 04:53 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Oil passageway
John,
Why did Flint blocks have the pipe plug in that oil passageway, and Tonawanda blocks not even have it drilled out ??? I see what Tom did above, but I have NEVER seen that hole used for anything from the factory. Have you ???
RON
Old Sep 23, 2010 | 06:29 PM
jkuzzy's Avatar
jkuzzy
Originally Posted by SplitmanC2
Milano Maroon;
Al.
Splitman,
Just out of curiousity, what are the numbers on that block? I have a 64 with the incorrect engine and I am always curious as to what happened to my block.
