Finally! I've done something that actually shows some progress on the car. Now that the cluster's in, what the hell do I do with all those wires hanging around? I'm done for the day. Finished-up inside the car with the A/C, then got the cluster in and mated the dash wiring harness with the engine compartment and rear harnesses.
I've got the compressor and alternator mocked-in so I can do the engine compartment wiring.
Tomorrow, I'll try to wrap-up the wiring and get the parking brake & hood release re-installed. BTW, I did the cluster myself and think it came out looking ok. Only had to replace the ammeter, as all the other gauges checked-out as good.
Looking good, another step closer, I remember going thru all that, each step is an accomplishment and you can pat yourself on the back for the good job, keep us posted,.
Dave,
It looks like you have a heat barrier down. Did you run it under the center section of the dash? And I'm assuming you put it in before you put the dash in?
