Side Pipe Dilema
Old Sep 2, 2010 | 07:40 PM
BuffaloBILL's Avatar
BuffaloBILL
Default Side Pipe Dilema
Hey Gang
I am installing Sidepipes and I am getting closer to getting my 66 Coupe Out of the Body shop
They called me to ask if they should "Cut Off' the Rocker Molding Tabs
I knew that the front fiberglass fron edge 3 1/2 inches needs to be cut (Keeping Pieces) off But I did not realize that the tabs also needed to be cut Is there a way to bend them up? I am hesitant to cut them off or drill the "pop" rivets to remove them. The car was purchased from original Owner and I may decide to put it back to its Original state sometime n the future What are my options?
Please advise
BuffaloBILL
Old Sep 2, 2010 | 07:47 PM
62Jeff's Avatar
62Jeff
Bill,
The tabs can be bent over, so I've read here. If your concern is putting it back to original, how will you address the holes you have to cut in the rockers?
The good news is you can choose to do nothing right now, if you wish, and if you later commit to sidepipes you can install them in a weekend.
Jeff
Old Sep 2, 2010 | 07:55 PM
BuffaloBILL
Originally Posted by 62Jeff
Bill,
Jeff
Hello Jeff
You lost me, What holes? I guess I need to see a car that has them mounted
Bill
Old Sep 2, 2010 | 08:05 PM
62Jeff's Avatar
62Jeff
Originally Posted by BuffaloBILL
Hello Jeff
Bill
The holes you leave when you cut off the front and back of the rocker fiberglass to make room for the pipes. You said you'd keep the pieces, but if you put them back on later you'll have a repair you can see from the back, because I don't think that part of the car got blackout paint.
Old Sep 2, 2010 | 08:09 PM
wombvette's Avatar
wombvette
YOu can never go home.
Old Sep 2, 2010 | 08:32 PM
DansYellow66's Avatar
DansYellow66
There is room for stock size sidepipes if you bend over the metal rocker molding tabs. I once had a car done this way. I don't know about larger diameter, aftermarket side pipes - probably not.
You can repair the tabs, even the backside surface, given enough effort. Just hang on to them. You can buy dyes for fiberglass resin to match just about any color fiberglass. After that it's just tedious work to make an invisible repair. There is also a circular cut out of the rear wheel inner wheel well fiberglass that comes down over the end of the frame tube closure plate. It's to clear the curved end of the sidepipe as it turns out. Hang on to that also. You can see it in the detail in the AIM sheet excerpt above.
Dan
Old Sep 2, 2010 | 09:39 PM
mkh's Avatar
mkh
The only fiberglass that needs cutting is behind the front wheel. Nothing in front of the back wheel needs cutting. The tabs can be bent in with a wood 2 by 4 and a hammer.
Old Sep 3, 2010 | 07:52 AM
BuffaloBILL
I'm Starting to feel this way Anyone interested in Brand New Side Pipes and covers??
Bill
Old Sep 3, 2010 | 10:02 AM
Lee H's Avatar
Lee H
You can always go home! Do the car the way you want it now and change back IF you decide later.
Old Sep 3, 2010 | 10:03 AM
Larry N. Johnson's Avatar
Larry N. Johnson
Bill
I just spent a lot of dollars on all brand new; they should easily find a new home.
Old Sep 3, 2010 | 10:34 AM
MasterDave's Avatar
MasterDave
Moderator
I tried bending mine but with no luck. Had to cut them off.
Old Sep 3, 2010 | 10:45 AM
Mike Geary's Avatar
Mike Geary
Default Rocker Tabs
My coupe has the tabs bent back and GM sidepipes fit just fine.
Let me second the prior comment on NOT removing the rear body tab. Plenty of clearance.
But, if I ever go back to undercar exhausts - I doubt if the tabs can be straightened to make them fit.
Rather than bend them back (really looks ugly), I'd cut them off, leaving a stub on the down leg. Save the pieces (marked with position) and they can be MIG'd back on.
Old Sep 3, 2010 | 10:50 AM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Don't let those small mods scare you. You will love the sound and so will everyone that hears it. I just bent my tabs and only had to cut the front to let the pipe come through. Actually if you ever did decide to go back, the rocker cover covers the area you have to cut, so the mod is only visible from the back side. Go for it.
That reminds me, I need some new pictures of my car with the side pipes installed.
Old Sep 3, 2010 | 01:01 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
They look so and sound so you will never go back
Old Sep 3, 2010 | 01:54 PM
62Jeff's Avatar
62Jeff
Bill would you like to drive my 65 coupe again so you can remember what a small block with side pipes is like, before you make up your mind?
Jeff
Old Sep 3, 2010 | 02:23 PM
BuffaloBILL
Jeff
Jeff
Thanks for your generous offer. How about me droping the Coupe off so you can finish it and lending me your Vette as a loaner.?
Just kidding I would love to have you and Jay come by when I get the Vette back from the Body Shop
Thanks Again
Bill
To Side Pipe Dilema
By Michael S. Palmer | 2026-06-03 09:39:05
