Temp gauge
Old Oct 3, 2010 | 09:23 PM
RREEVES's Avatar
RREEVES
Default Temp gauge
My gauge just stopped working all of a sudden on my 63 vette, any ideas what I should check on.
Thanks,
Old Oct 3, 2010 | 09:27 PM
5thvet's Avatar
5thvet
Have you been doing any work under the hood in the area of the sender where you could have jarred the wire or any work behind the cluster?
Old Oct 3, 2010 | 09:34 PM
62Jeff's Avatar
62Jeff
If your fuel gauge also just stopped working, then check the fuse in the fuse panel as they share a common power circuit.
Old Oct 3, 2010 | 09:57 PM
jkuzzy's Avatar
jkuzzy
Which gauge?
Old Oct 4, 2010 | 08:53 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
To quickly check the operation of the gauge, just ground the green wire at the sensor, then remove it from the ground. The gauge should make a full deflection. The sensor simply varies the resistance to ground to swing the gauge. If the gauge fully deflects, the sensor is bad. Dave
Old Oct 4, 2010 | 09:54 AM
RREEVES's Avatar
RREEVES
Not really doing any work under the hood or behind the cluster, I do believe the fuel gauge still registers, but I will check the fuse in the fuse box, will the fuse box identity the fuse for the fuel & temp gauge? Also, where would the sensor be located, is this just a matter of following the wires from the gauge?
Thanks,
Old Oct 4, 2010 | 11:01 AM
5thvet's Avatar
5thvet
It would be the top left fuse and it not marked as temp gauge but say "Fuel Ga" If you fuel gauge is working it is not the fuse. The sensor fitting goes into the block up near the thermostat housing. If you look at the upper edge of the valve cover you will see an insulated wired running along that upper edge going from the dash harness thru the firewall along that valve cover to the sensor. That wire has a slide on connector to the top of the sensor. If you need a pic let me know and I can take on and post. I'm sure you'll be able to find it.
Don
Old Oct 4, 2010 | 12:46 PM
RREEVES's Avatar
RREEVES
I should be able to locate it, but I will double check that fuse you mentioned.
Thanks again for your help, Don.
Ron,
Old Oct 4, 2010 | 12:56 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Probably a sender. Be sure not to get one from the local auto parts. They aren't calibrated right. Buy from one of the Corvette suppliers.
Old Oct 4, 2010 | 01:02 PM
magicv8's Avatar
magicv8
If the fuel gauge works and removing and or grounding the wire at the temp sender does not move the gauge with the key on, disconnect the battery and carefully remove the (RH) bulkhead plug of the engine harness to check for corrosion on the contacts of the sender wire.
Old Oct 4, 2010 | 01:40 PM
JohnZ's Avatar
JohnZ
Thanks,
Assuming your tanker is a fuelie, the temp sender is located between the thermostat housing and the fuel filter; see photo below.
Old Oct 5, 2010 | 08:30 AM
RREEVES's Avatar
RREEVES
Thanks John and everyone, this is a wealth of valuable information, I will check your suggestions later this week......
Ron,
To Temp gauge
