1965 - Spark Plug Wire Support
Old Nov 3, 2010 | 10:22 PM
rad-man's Avatar
rad-man
Default 1965 - Spark Plug Wire Support
I don't have supports on any of my spark plug wires.
Searching didn't help.
does anyone know of a "kit" that includes everything i need. Or piece one together:
http://www.zip-corvette.com/GroupDet...ets+%26+Clips&
Any pictures of a proper engine compartment would also help.
TIA
Old Nov 4, 2010 | 12:16 AM
4440stevesvette's Avatar
4440stevesvette
Default sparkplug wire kits
I don't know of any "kits", but S-111, S-231, S-232, S-109 and S-349 are all you really need to get the job done. Good luck.
Old Nov 5, 2010 | 12:09 PM
Geek's 65's Avatar
Geek's 65
Default Maybe This Will Help?
Here's how they are supported "normally" (I think - may not be NCRS blessed)
Geek
Old Nov 5, 2010 | 12:49 PM
DZVette's Avatar
DZVette
Gary,
Nice reference pics.
Thanks!
Dave Z
Old Nov 5, 2010 | 06:39 PM
Texaspilot180's Avatar
Texaspilot180
Excellent pics. I'm at this stage myself on my 65 FI Coupe, should have the engine back from the shop early next week so this was good timing for me as well. Hope to get my 4 speed mated and the engine/tranny dropped in before paint goes on in about 2 weeks. Getting closer by the day!
Old Nov 23, 2010 | 05:23 PM
rad-man's Avatar
rad-man
I found the kit:
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
It's sad that a single piece of this wasn't left on my car when I got her.
Old Nov 23, 2010 | 06:07 PM
1Sweet66's Avatar
1Sweet66
Can you imagine changing out these wires with the engine in the car!
Great reference pics by the way.
Hope to be at that stage some time soon myself.
Old Nov 23, 2010 | 06:39 PM
4440stevesvette
Thats why I don't have any of the spark plug shielding on my '65 coupe, only the distributor piece and the 2 pieces that go down vertically!!! The rest is enogh to drive you CRAZY!!!!!
Old Nov 24, 2010 | 02:43 PM
JohnZ's Avatar
JohnZ
[IMG] Can you imagine changing out these wires with the engine in the car!
Yup, I'm doing that now . Fortunately, not an A/C car.
Old Nov 24, 2010 | 04:32 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
there are worse cars to change wires on
Old Nov 25, 2010 | 10:40 PM
kskid's Avatar
kskid
4440 what did you use on the manifolds? look good
Old Nov 26, 2010 | 11:39 PM
4440stevesvette
Sorry, but those were not my pictures. I only made the comment that I only run my dist. cover and the two vertical wire coverings. Anything more is just WAY TOO MUCH for me to dick around with. I have used exhaust manifold paints but without much success once the engine is fired up and it gets up to operating temp.
Old Nov 27, 2010 | 11:57 AM
Geek's 65's Avatar
Geek's 65
They are ceramic coated. Had them done over 5 years ago and that's how they look today.
Geek
Old Nov 27, 2010 | 05:39 PM
GUSTO14's Avatar
GUSTO14
Geek
Geek...
Who did you use?
Thanks, GUSTO
Old Dec 6, 2010 | 02:03 PM
rad-man's Avatar
rad-man
I purchased all the wire supports, but I'm having slight difficulty installing them.
Specifically, I can't get these bolts out. They are really tight and I don't want to break them or Eff up the threads. i've hit them with PB blast over the past 2 days...
Any other suggestions? They look important.
Old Dec 6, 2010 | 07:54 PM
Geek's 65's Avatar
Geek's 65
Originally Posted by GUSTO14
Geek...
Who did you use?
Thanks, GUSTO
Sorry for the long delay in response. I used a local company here in Camarillo, CA. They are no longer around but certain you can get ceramic coating pretty much anywhere.
Geek
Old Dec 6, 2010 | 08:30 PM
62Jeff's Avatar
62Jeff
I'd think those should only be torqued to about 35 lb-ft. They go into the head and likely have thread sealer or locktite on them.
Try using a 6 point socket on it to loosen it, if you haven't already. It will minimize the chances of rounding the head.
Old Dec 8, 2010 | 12:20 AM
rad-man's Avatar
rad-man
got it. those 2 bolts were way tighter than i expected!
Old Dec 8, 2010 | 12:35 AM
62Jeff's Avatar
62Jeff
Much better.
Did you replace the bad fuel pump?
To 1965 - Spark Plug Wire Support
