Keisler Trany Trouble
When you turn off car, put it in first, start engine while clutch is depressed,...does the car quietly sit there, does the idle sound correct, does it try to creep??
EVERYTHING IS FINE! just can't put it in gear. stays in nuetral. idle is fine, sounds correct, no creep. sits there guietly in nuetral!!!!
My point for asking about the shifting with the engine off is because if something is broken inside the gearbox, then it would have trouble going into gear whether the engine was running or not. An issue with the clutch on the other hand, will allow the transmission to go into gear with the engine off but have difficulty (or not go in at all) with the engine running.
Before I went to the expense of pulling the transmission and shipping it back to the company, I would exhaust every avenue first and that means making sure it is not a problem with the clutch or something else.....
Is the car using hydraulic clutch actuator system or mechanical linkage? If mechanical, make sure you have no more than 1/4" gap between the face of the bearing and the fingers of the pressure plate when the pedal is out at the rest position.
If hydraulic (Keisler Hydraulic) call their tech guy and ask about the stackup height of their bearing as it is different and if I remember correctly, needs to be in constant contact with the fingers of the pressure plate all the time....I remember reading on here and a Mopar forum they had issues a while back where the fluid would boil and you would lose the pedal......
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Received 1,946 Likes
Sounds like you never gave Keisler a chance. Right after your phone call to them, you started this thread complaining about having to pay shipping back to them. If you didn't understand you were required to pay shipping to them in the event of a warranty claim when you bought it, shame on you. It seems to me they are adhearing to their warranty to fix it and pay shipping back to you. It sucks when something breaks, but that is a risk we take when buying anything today, be it a washing machine or a new car or a transmission. All you can ask is the seller backs up their warranty and in my opinion, Keisler is doing that.
Test as chuckie says. If the car starts without moving, continue to hold the clutch in and shift to neutral and back into reverse. If the clutch has been down all this time, the transmission will not have turned at all. Reverse should go in without grinding.
That is true in some cases, however, first and foremost in this situation, somebody needs to successfully isolate the culprit component. It might be the tranny, it might not. A vendor needs to be roasted only after his component is identified as the culprit, and the customer, reasonably feels that he is getting the end of the stick with the stuff on it.
Chuck
Chuck
Sounds like Keisler already had it diagnosed.
Believe me, I am not defending them (or bashing them), just stating what others in the industry do in these situations.....
If it can be determined over the phone that it is DEFINITELY a transmission issue, then a call tag would be appropriate IMO.....
Sellers in todays market need to go the extra mile. It's not always about the written warranty. Especially when a middle man is involved. Gotta make sure EVERY customer is happy. Or threads like this can start.
In my business, the customer is always right. I will refund their money or whatever it takes. Even if the customer IS wrong. The cost of an unhappy customer is too high. The damage to my business to high. It's best to take your loss. Than have people like us talking about the deal on the internet. Everytime we post, it drives the thread right to the top. If I owned Keisler, it would be making me very uncomfortable.
Eliminate the words "Keisler" and "Tremec" from the origninal post and everyone would have been telling the OP to check his clutch/throwout/pilot bearing instead of chewing on the vendor.
Just because it upshifts doesn't mean you don't have a clutch problem!
Heck, you don't even really need a clutch to upshift if you do it right!
Have you tried double clutching and rev matching when downshifting?
DT
To me, Tux is asking for some diagnostic guidance. Maybe an old hat, close by, could lend some of those decades of experience to the op.
The last thing we need to see is a removal, shipment, and vendor diagnosis of ok.
Regards,
Chuck
#33
When one of your customers has to come here to complain? You've dropped the ball.
Instead of debating the warranty conditions. Just make the guy happy. This thread alone will cost you more than paying the shipping.
It takes many new customers to make up for the damage done by one unhappy customer.No matter who is in the right.
Put yourself in your customers shoes.
IMHO. Your only response on this Forum should have been you are contacting the customer to make sure it's worked out to his satisfaction.
I have considered buying a Tremec from your company. But I keep running into threads like this every few months.
I agree with your opinion that a solid response is making sure it's worked out with the customer. The holy grail of customer satisfaction.
BUT - The OP did come here to complain and his statement was that he thought Keisler was lame because they were making him pay to send it back. Which if you just take that at face value makes Keisler appear non-responsive. I think it's professional and completely fair for Keisler stand up and simply add the fact that the warranty states the customer pays return shipping. Didn't dis the OP or try duck the issue. Pointed out the warranty fact and if the customer will do his part - they will do theirs with two points of contact to boot. Customer service is the mainstay but I my opinion that's exactly what Keisler is providing while at the same time pointing out (albeit not directly) that they are not out "to screw the purchaser" (KC John's post).
As for the real issue of what is the problem - my first look would be the clutch as well. New or not. We have all seen multiple threads of "my brand new clutch died" on this forum. Since the car consistently goes into gear when it's off without problem, to me that makes the clutch the prime suspect here.
Just my 2cents.
#34
DT
#35
I've experienced 2 instances in my life where a clutch or throwout bearing issue caused the symptoms described - can't shift in gear with the car running, can only shift with the car off, in other words - something keeping the input shaft from becoming disengaged from the flywheel (for all practical purposes).
Hopefully you are able to find what it is before shipping the transmission out.
#36
#37
#38
thanks , i'll give it a try tommorrow!!!
#39
A piece of disc material smaller than a dime can cause it.
