C2 Prototype testing
Old Dec 10, 2010 | 03:44 PM
vetrod62's Avatar
vetrod62
These should explain a lot.
Old Dec 10, 2010 | 05:42 PM
Stewart Allison's Avatar
Stewart Allison
That's what we needed. I was surprised to see the C1 cd figure so bad. After that wind tunnel test seeing the windscreen coping a beating by the wind it doesn't surprise me. The C2 lift is amazing ! The c4/5/6 are real slippery buggers ah. Interesting thread. Stewy
Old Dec 10, 2010 | 09:44 PM
sub006's Avatar
sub006
Originally Posted by kskid
When I first got my 65 with a 427 in it, I had to top end it later on. It ran out of steam from the lifters at 155mph. But it was glued to the road.
That big anchor held the front end down better than a small block.
Old Dec 10, 2010 | 09:50 PM
sub006's Avatar
sub006
Originally Posted by Stewart Allison
There is something about an e type ? Not sure why I like them nothing really stands out except for the oil leaks lol. The S/W with the knock of rims in silver is a very modern car compared to the english e type. Stewy
Well, the E's monocoque (aircraft-style) chassis-body was an advancement over Corvett's body-on-frame construction. It had discs and IRS before Chevy adopted them. And the C4 (sort-of) tilt front end arrived 23 years after the E pioneered that kind of engine access.
But I'd take a C2 anyway. Less to go wrong, and MUCH simpler to fix when it did.
Old Dec 11, 2010 | 08:59 AM
mashinter's Avatar
mashinter
The Sting Ray shape was that of an inverted airfoil. The idea was to create downforce with that shape. Frank Winchell's comment years later was something like "We were clueless about ground effects. It would have worked if it were 50 feet off the ground!."
They probably did their high-speed testing on a banked track, where the lift was masked by additional downforce due to the banking.
Barry Bock ran a 396 Sting Ray coupe at Bonneville in 1965 to 170 mph and didn't have a blowover...
Old Dec 11, 2010 | 04:52 PM
63Corvette's Avatar
63Corvette
THIS is how they tested the C2:
http://bangshift.com/blog/Incredible...us-Duntov.html
Old Dec 11, 2010 | 05:07 PM
zpletcher's Avatar
zpletcher
Default Gimmicks and Gadgets
Originally Posted by Dan Hampton
Credit Bill Mitchell with the lift. He was warned by Pete Brock, a designer at GM who worked on the first renderings of the Stingray, of the potential aero problems presented by the front end. Brock went on to design the Cobra Daytona Coupes which, incidentally, did not lift at 190 mph.
Wally Wyss, who has written extensively on everything automotive, once said that while Shelby & Co. was pouring much of Ford's money into making the Cobra and Mustang more competitive and world beaters, "Mitchell was spending millions of dollars on James Bond type gadgets like revolving license plates"......
No argument on the Stingray design, though. It was one of a kind.
GM has been known for years to offer too many "Gimmicks and Gadgets"
in lieu of functionality..
Old Dec 12, 2010 | 09:28 PM
Stewart Allison
I was following a local made car the other day. The latest offering from the factory is to put a rear defuser under the car. Most Race cars seem to be running them. The car was a GM Corvette motored, Holden Special Vehicle that we make. It pumps out 410 bhp and it ain't a shabby car. While I was following this car I noticed the rear diffuser was flexing so much it was acting as a parachute. When we pulled up at the lights I signaled the guy to pull over. I told him he was going to loose his rear diffuser. He got out and I showed the guy that it was going to come off. When we pulled at it it wouldn't budge ? I got under the car and pulled at it real hard and it only moved slightly ? I was shocked and he was telling me the fuel economy was real bad. I told him while he was traveling at 50 mph it was flexing half a foot and more.
It was the first time I have ever thought about the air that travels under a car. I never realized that it was so significant. Even the add on diffuser from GM doesn't work and it's all for a look. I would say at 150 mph this rear diffuser would of torn off for sure acting like a parachute !
I'm not surprised that the C2 has a large amount of air pushing under the car after looking at this other scenario !
Here is a picture of a rear diffuser. Stewy
Old Dec 12, 2010 | 10:45 PM
tropicmoon's Avatar
tropicmoon
7th Gear
Originally Posted by ps374
I have heard on many occations that the C2s front lifts at high speeds. What kind of testing did they have in the early 60s to test such things? Couldnt this problem if its true have been prevented while the car was in its design stage? Was the C1 more stable at high speeds? Anyone?
way back in 1964, i had just picked up my 64 roadster. on one occasion, i cranked it up to 125mph from champaign ill to rantoul. that's when the front lifted off and got my attention. not very scientific, but it was a reality check.
dick
Old Dec 13, 2010 | 11:33 AM
JohnZ's Avatar
JohnZ
Managing the airflow under the car and how it exits at the rear provides more downforce (on an all-out racing car like a Formula 1 or Indy car) than the front and rear wings produce, with far less drag for the amount of downforce produced. That's why the FIA rules are so specific about ground clearance and rear diffuser designs.
Old Dec 13, 2010 | 12:20 PM
Poorhousenext's Avatar
Poorhousenext
Originally Posted by JohnZ
They did the same thing in the wind tunnel - photo below is the full-size fiberglass styling model of the Corvette SS in the Lockheed tunnel in Marietta, Georgia, in December, 1956. This model was cut up after the tunnel tests and the skin ended up on the SS "mule" (the chassis of which later became Mitchell's Sting Ray).
I'm a little puzzled by any Wind Tunnel testing being done by Lockheed Aircraft in Marietta, Georgia in 1956. Not saying it's not possible.
Government owns the property know as Air Force Plant 6. Plant 6 was closed in 1946 and remained closed until Lockheed rented it in 1951 to do AC modification work.
My career with Lockheed at Plant 6 Marietta, GA did not start until Feb of 1963, so I could be wrong. To my knowledge the government did not build a Wind Tunnel on the Plant 6 campus. Never saw a building that came close to resembling base design needed to support fans large enough for up to 200 MPH wind test.
Lockheed did not opened their Commercial Low Speed Wind tunnel built on property they own adjacent to Plant 6 until 1967.
Are you sure testing location is correct for date it took place?
I could probably verify I'm right or wrong. I know one manager that transferred from Lockheed's old Burbank Plant in 1951 to run manufacturing planning devision that would know as he spearheaded the Plants Museum effort, plus Air Force files on Plant 6 should list building.
If you think "Government Bail Outs" and "To Big to Fail" is new, you might want to take a look at article below...LOL
http://www.georgiaencyclopedia.org/n....jsp?id=h-1337
Old Dec 13, 2010 | 12:54 PM
JohnZ's Avatar
JohnZ
Could well have been a different tunnel in 1956; I know we rented the Lockheed tunnel in Marietta many times in the late 60's - early 70's (for $16,000 per day) before we built our own full-size tunnel at the GM Tech Center.
