Identifying engine??
Old Jan 16, 2011 | 07:27 PM
5thvet's Avatar
5thvet
[QUOTE=joseph p;1576530423]
Originally Posted by 5thvet
AFB on the 300 vs WCFB on the 250, different intakes 3844457 for the 250, 3844459-300, 2" exhaust on the 250 vs 2 1/2" on the 300 ( if manual trans).
I thought 1965 250 heads were different from those earlier. What size were the valves pre 65 as opposed to 65s?
No I think the heads etc are the same on a 65 but different on 63 and 64.
Old Jan 16, 2011 | 07:37 PM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by joseph p
[IMG][/IMG]
looks like 312595, (or 395) not 512395.
Comments on the font?
Old Jan 16, 2011 | 07:55 PM
1snake's Avatar
1snake
That's a terrible looking pad. This is typical of a 65 300HP pad.
Old Jan 16, 2011 | 07:58 PM
62Jeff's Avatar
62Jeff
Heads were the same on all 65s, but Intake valves were 1.94 on lower horse engines, 2.02 on the 350 horse and up.
Old Jan 16, 2011 | 08:03 PM
vettebuyer6369
I was being polite. That SN is ridiculous.
Old Jan 16, 2011 | 09:12 PM
emccomas's Avatar
emccomas
That is a very bad restamp. Probably not intended to fool anyone. Definitely not a factory stamp.
Thanks for posting the pics.
Old Jan 16, 2011 | 11:04 PM
stingrayl76's Avatar
stingrayl76
Looks as if it's a poorly restamped 67 block done by someone trying to fake a matching numbers 65.
Old Jan 17, 2011 | 09:35 AM
joseph p's Avatar
joseph p
Engine has less than 30k miles on it, same owner since 1967, never been apart during that time. Not likely someone would restamp a '65 engine prior to 1967 ...is it?
Old Jan 17, 2011 | 09:49 AM
Mike Ward's Avatar
Mike Ward
Joseph,
The appearance of the pad is not similar to any GM engine I've seen, Corvette or not. The engines were built in one plant and installed in another. Each plant used a different set of stamps first to identify the engine and then tie it via the VIN derivative to the car. The two stamps were of a different sized font and were relatively straight and orderly being secured in a gang holder.
If you compare your photo to the example of a factory pad further up the difference is apparent.
It's impossible for others to know what the true history of your engine is or what's really inside it.
Old Jan 17, 2011 | 10:10 AM
joseph p's Avatar
joseph p
So you're saying that something like this has never been seen before by the experts in this area on a pre-67 block. Even though the man has owned it for 43 years and has no reason to lie as well as being known personally by his friend during those years.
Seems as though this is a rare exception from a day when the "stamper" wasn't on top of his game, or there are others out there that we don't know about, or between 1965 and 1967 this engine in it's early mileage was taken apart and restamped?
I was actually only trying to read the stamping on this engine for him, now it's turned into a mystery.
Old Jan 17, 2011 | 10:48 AM
Mike Ward's Avatar
Mike Ward
Joseph,
We're trying to help you out, that's all. There's no real difference to pre '67 or post '67, GM's methods didn't change much for many decades.
The 'stamper guy having a bad day' story doesn't hold up. There were two stamps by two different guys in two different plants done weeks or months apart on 'typical' engines. Yours looks like it was done all by the same guy at the same time with the same stamp. Sorry.
Here's another example of a typical, this from a '72
Note also on this one are front to rear broach marks which are seen on factory blocks. Yours seems to have a polished or rotary milled surface.
My guess is that it was decked, rebuilt and restamped, reasons unknown.
Try posting the casting number and date for the block, this might narrow down when the engine was actually made.
Old Jan 17, 2011 | 11:13 AM
62Jeff's Avatar
62Jeff
Since the engine has truly been together for so long, then I'd guess that something went wrong with the engine early in its life, the engine surface was decked, and whomever rebuilt it put the old numbers back on the block in order to keep the info (or keep it legal?). It would have pre-dated all the hoop-la that surrounds restamping engines in order to meet NCRS/Bloomington judging criteria.
Old Jan 17, 2011 | 11:58 AM
  #33
joseph p's Avatar
joseph p
I guess that makes sense.
Old Jan 17, 2011 | 12:25 PM
  #34
stingrayl76
The dilemma is that it's not a 65 engine because the 3892657 casting wasn't available in 65. If that engine was in a 65 Corvette, it was installed sometime after the car left the factory. Take a look at the casting date located at the rear of the passenger side head and post it. That will verify when the engine block was cast.
Old Jan 17, 2011 | 01:54 PM
  #35
JohnZ's Avatar
JohnZ
Here's where to look on the rear of the block for the casting date.
Old Jan 17, 2011 | 03:43 PM
  #36
vettebuyer6369
Not really...they aren't saying they have never seen anything like it. They are saying they have never seen numbers like that which were not decked and restamped for whatever reason. As was previously stated, "having a bad day" has no relation to SN font that are incorrect.
Old Jan 17, 2011 | 03:56 PM
  #37
JohnZ's Avatar
JohnZ
No mystery - clearly, the engine has been replaced at some point in the past, and whoever replaced it stamped it one character at a time, using whatever he had handy, with the numbers from the original engine.
To Identifying engine??
Old Jan 17, 2011 | 04:46 PM
  #38
TheSaint's Avatar
TheSaint
Looking at the correct stamp on a engine makes me think that there can not be a problem for a skilled mechanic that have the right tools to stamp a engine whatever way he feels like
Old Jan 17, 2011 | 08:20 PM
  #39
joseph p's Avatar
joseph p
Looks like it says A 97
Please don't think I'm trying to be defensive, I appreciate all the input that you've all given me.
Old Jan 17, 2011 | 08:27 PM
  #40
1snake's Avatar
1snake
It's a Flint block that was cast Jan 9 1967
Jim
