64' Rolling Chassis?
Old Jan 24, 2011 | 01:13 PM
jmyers85's Avatar
jmyers85
Cruising
Default 64' Rolling Chassis?
Ok, I am trying to correctly I.D. my mid-year rolling chassis. I recently purchased a rolling chassis and was told it was a 64' but recently read somewhere that they did not introduce the gussets in front of the rear kickup until 64. This is why I am confused because my frame does not have the gussets... does this make it a 63'? How can I correctly I.D. my midyear frame? Any help would be greatly appreciated
Old Jan 24, 2011 | 01:24 PM
DansYellow66's Avatar
DansYellow66
I don't believe any gussets appeared near the seat belt anchors until 1965, along with the indentations in the back rails to clear the rear disc brake calipers and the dent in the front cross member for the big block damper. Sounds like it could still be a 64. The 63 frame had two additional inner body mounts near the transmission tunnel at the differential cross member. These were dropped after 63. Also the 63 body mount brackets were slightly higher than those in later years because they didn't use any rubber body cushions. But without comparing them side by side or having a measurement it's probably hard to tell them apart.
Old Jan 24, 2011 | 01:34 PM
wilbur's Avatar
wilbur
My 64 (sold years ago) had no gussets. Can you see the V.I.N stamped in the frame?
Old Jan 24, 2011 | 07:26 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Late 64 had the gussets the early did not, also the 63 frame had 2 holes in the driver side center crossmember for the E brake cables, 64 had one hole with a bracket in the center for the E brake leaver.
Old Jan 24, 2011 | 10:06 PM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
Later '64 frames after May of '64 have the gussets and the 63/64's before that date had none. Info is from the '63/64 NCRS judging guide. Dave
To 64' Rolling Chassis?
