Headers
Old Jan 31, 2011 | 06:56 PM
32361ARTHUR's Avatar
32361ARTHUR
Default Headers
I just finished putting a 383 stroker in my 63 coupe. The motor got 410 HP and 440 TQ on an engine dyno before installation. I just drove it to Sacromento and back here to Las Vegas and then from Las Vegas to Los Angeles and back. While in Los Angeles a friend told me I should get rid of the stock manifolds and go with headers. I called the engine builder and he said the same thing. Today I ordered a set of Hooker Super Comp headers with one and three quarter tubes and a 3 inch collector. I was told they will work. Does anybody on here have any experience with these in a C2. I'm hoping they will not be lower than the frame rails or I will go with something else. Dave
Old Jan 31, 2011 | 07:05 PM
Scott Marzahl's Avatar
Scott Marzahl
AHoover posted some good pics on how low Hookers are compared to Dynomax headers.
http://forums.corvetteforum.com/c3-t...ns-please.html
Old Jan 31, 2011 | 07:23 PM
32361ARTHUR
Thanks for the quick reply. It looks like either one will work but I looked up Dynomax and they don't list anything specific for Corvettes under the applications. Dave
Old Jan 31, 2011 | 08:04 PM
fullcontrol's Avatar
fullcontrol
Paid Senior Member
I went with a set of this direct replacements. don't have any dyno numbers yet. They are direct fit replacements.
http://www.vetteheaders.com/servlet/...ders%2C/Detail
Old Jan 31, 2011 | 08:08 PM
32361ARTHUR
Those are probably great but they aren't for a small block are they?
Old Jan 31, 2011 | 08:11 PM
jkuzzy's Avatar
jkuzzy
My Hedmans hang down a little, but not too much. I just don't go looking for speed bumps...
Old Jan 31, 2011 | 08:13 PM
fullcontrol
Paid Senior Member
First line of the description:
The headers that fit 396, 427, 454, and 502 corvettes from 1965...
A quick way to tell SB and BB apart is if they are evenly spaced then you are looking at BB and if the two in the center are closer together then you are looking at SB manifolds/headers.
Here's a link to McJacks. there is a how-to article on the front page, if you want to do it yourself.
http://www.mcjackscorvettes.com/
Old Jan 31, 2011 | 08:21 PM
fullcontrol
Paid Senior Member
Sorry, me forgets 383 is small block, duh!
Here's another link for you.
http://www.vetteheaders.com/servlet/...orvette/Detail
or might be better to start here
http://www.vetteheaders.com/servlet/...rvette+Headers
Old Jan 31, 2011 | 08:30 PM
32361ARTHUR
I have rack and pinion steering in my car but I don't think that will be a problem. I got some that are ceramic coated inside and out. Will that pretty much eliminate any under the hood and floorboard heat problems or can I expect the heat to be noticeably higher? How about a starter shield, will I need one of those, I'm running one of those hi torque small ones. I was going to go with one of the short header manifolds from MacJack because it would be nice and clean and simple. My engine builder said I needed full length headers to get the most HP out of this engine. Dave
Old Jan 31, 2011 | 08:40 PM
steersdad's Avatar
steersdad
Default rack & pinon issue
I have rack and pinion steering in my car but I don't think that will be a problem. I got some that are coated inside and out. Will that pretty much eliminate any under the hood and floorboard heat problems or can I expect the heat to be noticeably higher? How about a starter shield, will I need one of those, I'm running one of those hi torque small ones. I was going to go with one of the short header manifolds from MacJack because it would be nice and clean and simple but my engine builder said I needed full length headers if I want to get the HP out of this engine. Dave
You will need to check with the R & P manufacturer on which headers will fit. Not all do.
As for heat issues, get ceramic coated headers. This will minimize heat transfer out of the tubes into the car. You can always use thermal wrap on the headers also. I have done this on several cars. Looks dumb, but works.
When changing from cast manifolds to good headers, like hooker super comps, you will find the HP increase notable. I used 2 1/2" chambered exhaust under the car, and it sounds great.
Old Jan 31, 2011 | 08:49 PM
32361ARTHUR
At this point I have already ordered the Super Comp headers and will know by the end of the week if the rack and pinion will be a problem. It looks like it won't be but nothing surprises me anymore. What are CHAMBERED exhausts?
Old Feb 1, 2011 | 12:20 AM
jkuzzy's Avatar
jkuzzy
Think side pipe sounds.....Ahhhhhhh.....
Old Feb 1, 2011 | 10:44 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I have Hooker Super Comps (p/n 2134) on my '65 and on my '78. They work great!
__________________
1965 Convertible
NCCC 2B National Drag Record Holder
11.34 second 1/4 Mile
Old Feb 1, 2011 | 02:01 PM
32361ARTHUR
I am glad to hear that, especially that they fit your 65. I ordered the same ones. I never got an answer back as to what a "chambered" exhaust means, do you have an answer to that? What kind of mufflers do you use on your 65? I see that yours is an eleven second car, is it also driven on the street? Thanks, Dave
Old Feb 1, 2011 | 02:52 PM
larrywalk's Avatar
larrywalk
Chambered exhaust is a series of crush bands on the pipe itself like is used on side exhaust pipes for the mid-years. (I have heard that they don't flow as well as a low restriction muffler.)
For my normal exhaust, I prefer a full 2 1/2" system to low restriction mufflers such as the DynoMax Ultra Flows.
Disclaimer: No muffler was harmed in the setting of any record!
Old Feb 1, 2011 | 04:23 PM
Scott Marzahl
Chambered exhaust are not as free flowing as a good set of turbo style mufflers.
Here is a link to chambered mufflers so you can see what they look like.
http://www.classicchambered.com/classic/products.html
Old Feb 1, 2011 | 04:53 PM
steersdad's Avatar
steersdad
Default Chambered exhaust
Sorry for the slow reply. Been up to my keester in snow, again..
I have owned and raced big & small block vettes for over 40 years. Now, I have never made an actual dynamometer test comparing chambered pipes to a turbo muffler, or open pipes for that matter. However, the chambered exhaust pipes flow straight through a tube, from end to end. While even a turbo muffler causes the exhaust gasses to turn direction once or twice. Their design intention is to reduce noise with a minimum of back pressure. But to say performance is improved by using turbo mufflers over chambered exhaust? I'd like to see the dyno sheet. Not just an opinion.
Check this YouTube video for what they sound like. I installed under car exhaust so the sound goes out the back of the car, instead of exiting by my head. I have lost the hearing in my left ear thanks to loud exhaust.
Check this out. Mine sounds the same, with super comps as you ordered.
http://www.youtube.com/watch?v=atcbyr0rXoA
To Headers
Old Feb 1, 2011 | 05:19 PM
Scott Marzahl
The problem with chambered exhaust is that the ID is greatly reduced by all the teeth that stick up into the airflow path. These change the laminar airflow into turbulent airflow while increasing system backpressure. If you use them, get the largest diameter you can fit.
Old Feb 1, 2011 | 07:45 PM
32361ARTHUR
My car has a 200R4 trans in it with a modified crossmember. There are two holes that the exhaust goes through and I don't know if that is stock or not. The O.D. of my present pipes is about 2 1/8" and they lead to Dynomax mufflers. I might be able to go with 2 1/2" pipe all the way. Right now my biggest concern is weather the drivers side header will fit because I have rack and pinion steering and there might be a clearance issue.
Old Feb 1, 2011 | 09:31 PM
32361ARTHUR
Larrywalk, could you tell me how close your headers come to the frame rail on the drivers side. I have a bracket on my frame rail about even with the center port on the engine that holds a shaft for my steering. Thanks, Dave
