engine Id help
Old Feb 7, 2011 | 12:24 PM
ry57pont's Avatar
ry57pont
Default engine Id help
Where can i find the "numbers" on my 64 block? i was trying to find out if it is correct. Thanks - RB
Old Feb 7, 2011 | 12:31 PM
JohnZ's Avatar
JohnZ
The casting number is on the rear flange of the block on the driver's side, and the casting date is in the same place on the passenger side, about 6" from the distributor. The engine plant stamp and the assembly plant VIN derivative stamp are on the machined pad directly in front of the passenger side cylinder head.
Old Feb 7, 2011 | 02:18 PM
stingrayl76's Avatar
stingrayl76
Default Engine I.D.
http://www.yearone.com/updatedsingle...gineinfo6.html
Old Feb 7, 2011 | 02:47 PM
ry57pont's Avatar
ry57pont
thanks! looks like its a mystery motor , i have only looked where the vin code is and its smooth, no markings whatsoever. when i go back this weekend i will look at the date code to see if i can figure this out. - RB
To engine Id help
