Rag Joint Replacement
Old Feb 8, 2011 | 02:06 PM
jtranger's Avatar
jtranger
Default Rag Joint Replacement
I need to replace the original rag joint on my '65. The suppliers have the kit for about $14.00 that includes the rag and 4 bolts. I am not looking for original but are these decent rag joint kits?
How is the joint removed and replaced? Do I have to move or adjust the steering column? Larry
Old Feb 8, 2011 | 03:01 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
If you're lucky, you won't have to mess with the steering column.
1. Unbolt the two halves of the rag joint.
2. Loosen the 'special' bolt on the upper half and slide that half up the steering column.
3. Remove the 'special' bolt from the lower half and slide that half up off the steering box and out.
4. Slide the upper half down the column and out.
5. Reverse the procedure for installation.
I used one of the cheapie kits and the only drawback I found was that the supplied bolts weren't shouldered. I got around that by modifying my old 'pins' and using them instead of the unshouldered, supplied bolts. Don't forget your ground strap.
Last edited by nassau66427; Feb 8, 2011 at 03:12 PM. Reason: new and improved spelling
Old Feb 8, 2011 | 07:21 PM
jtranger's Avatar
jtranger
My joint has the original rivets so I can't split it while on the column. Will it still slide up and off? Where is the ground strap? Isn't it in the rag joint material?
Old Feb 8, 2011 | 07:47 PM
Kensmith's Avatar
Kensmith
I would consider buying a new rag joint VS rebuilding the old. Just a safety issue with me.
Old Feb 8, 2011 | 09:13 PM
nassau66427
If it's all riveted (tele column?) and there's nothing you can unbolt, then you'll have to loosen the steering column and draw it back somewhat to remove the steering coupling.
The ground strap was originally a separate piece inside the rag joint. You'll see it when you get your steering coupling apart.
A lot of the replacement rag joints have bits of screen door material glued (vulcanized?) on to them to take the place of the ground strap.
Old Feb 8, 2011 | 10:41 PM
jtranger's Avatar
jtranger
CC has a new upper coupler with the rag. Can I use the new upper coupler with the old lower coupler? Anyone have a photo of their coupler? I want to make sure mine is installed right. Attached is a photo of my coupler. Previous owner had Bubba working on the car!
Old Feb 9, 2011 | 09:33 AM
ricks327's Avatar
ricks327
Here is a picture of my 67 rag joint.
Rick
Old Feb 9, 2011 | 10:15 AM
jtranger's Avatar
jtranger
Thanks Rick, But the 67 is different from the '65.
Old Feb 9, 2011 | 10:18 AM
Blk63Vette's Avatar
Blk63Vette
Hello
I would get it rebuilt..There is a guy on this forum that can rebuild your own rag joint. Dont use the Cheap chinese parts..
Old Feb 9, 2011 | 12:21 PM
JohnZ's Avatar
JohnZ
Here's what a '63-'66 standard column rag joint looks like; most of the "kits" are a poor excuse for a safe flexible coupling, especially the ones with a molded plain rubber "rag" and non-shouldered bolts. Either get a new one (LICS has them) or get yours rebuilt (www.corvettesteering.com).
Old Feb 9, 2011 | 12:32 PM
nassau66427
Unbolt it at the pins and you can remove it as per my suggestions.
When you put it back in make sure the rag joint is 'flat' when viewed from the side.
What you have now is unsafe. The upper part of your coupling is too far up the shaft. The pins don't appear as if they would engage the upper part of the coupling in the event of a rag joint failure.
Old Feb 9, 2011 | 05:30 PM
jtranger's Avatar
jtranger
Thanks Everyone! Thanks Larry and John for the photos and details!
Old Feb 9, 2011 | 05:48 PM
iflyto's Avatar
iflyto
[QUOTE=jtranger;1576742613]CC has a new upper coupler with the rag. Can I use the new upper coupler with the old lower coupler? Anyone have a photo of their coupler? I want to make sure mine is installed right. Attached is a photo of my coupler. Previous owner had Bubba working on the car!
I think your Bubba knew a little more about rag joints than the one who worked on this one!
Old Feb 9, 2011 | 05:57 PM
Kensmith's Avatar
Kensmith
[QUOTE=iflyto;1576748921]
That's totally wrong............it's like not even close. Looks like two of the same halves put together and doing absolutely nothing but joining the shaft with the box. The rag portion is being used as a washer VS vibration damper.
Old Feb 9, 2011 | 06:00 PM
DansYellow66's Avatar
DansYellow66
That's classic - should be saved for posterity. Probably wondered why he had a notchy feel as he turned the steering wheel.
Dan
Old Feb 9, 2011 | 09:56 PM
jtranger's Avatar
jtranger
Just pulled the couplers and the rag was completely shot. The lower coupler was slightly loose even though the special bolt was tight. In the picture below, does the steering box shaft appear normal with excessive wear or grooves? I am hoping the lower coupler was the problem since it had some slight wear on the splines.
Old Feb 10, 2011 | 11:28 AM
nassau66427
Was the bolt rusty tight or 30 ft. lbs. of torque tight?
30 ft. lbs. will put a good squeeze on the coupling.
The groove on the steering box shaft is where the special bolt goes to locate the lower half of the coupling.
To Rag Joint Replacement
Old Feb 10, 2011 | 11:30 AM
jtranger's Avatar
jtranger
Larry, It was very tight!!
Old Nov 28, 2025 | 10:49 AM
'67 Topless's Avatar
'67 Topless
I am currently encountering a situation that has me confused. My car currently has a "gap" where the rag joint would be located (i.e. the end of the steering wheel shaft and the aft side of the steering gear). I currently have all of the brackets removed that would retain the steering wheel, which are located under the dash, and my son is supporting the steering wheel inside the vehicle. Therefore, I have the steering wheel pushed forward as far forward as it will go. To provide some further background, I performed a frame off, and I am using the same steering wheel and it was not disassembled. Any recommendations or suggestions that you may have to resolve this are greatly appreciated. Thanks
Steering wheel pushed forward in vehicle
Gap at Rag joint
Gap at Rag joint
Steering gear
Steering gear
Steering gear bolted to frame - under the vehicle
Old Nov 28, 2025 | 12:05 PM
65GGvert's Avatar
65GGvert
Where's the rest of your rag joint hardware? Try backing the camera up so we can see a picture of the entire set up. Look at the pictures posted 14 years ago in this thread of what it should look like, not the bubba one.
