Dot 5, Silicone
JIM
it was recommended to me because i live in a very humid location (90% as i sit here at 10 at night) - because it doesn't absorb water supposedly i will have less corrosion in the system - that is how this all came about
Using Dot 3, you HAVE to maintain it or you will have water, sludge, corrosion problems.
Using Dot 5, you have to do....................well, nothing.
Fixed calipers with four small pistons (as used on a C2) seems to have unique problems of their own compared to the floating, large bore calipers used on most production cars that also seem to require little if any maintainance using the factory fill.
Stuck pistons due to corrosion on small bore wheel cylinders on drum brakes also seem to be a thing of the past using Dot 5. Of course, most OEM's don't use drum brakes any longer.
It's very humid where I live most of the year and NO problems due to stuck, corroded brake parts.
in going to switch the fluid, i found a caliper leaking - wanted to rebuild them, but have now found they are not the correct parts
wanting to preserve the option to judge, i got some rebuilt calipers with the correct numbers
of course, while i was at it, i figured i should swap out the lines and rebuild the master and bought a kit and new lines (steel not stainless)
first section of line is from cylinder to brass junction block - it came with a 180 bend in the middle (in addition to the pre-bends at the master cyl end and the brass block end) - when installed, the 180 opens up to a 90 degree bend
my question is this: there is no way (without additional bending) you can feed the line under the clutch pedal support (going either front to back or back to front) - so, is is ok to bend the line early on to clear the hurdle and then unbend it once it goes through?
i am thinking it is ok, but wanted to ask
also, is there another way to feed the line so no additional bending is needed?
thanks
thanks
You need to ID what year of plug yer working on. Custom or modified. Power brake or standard.
Generally speaking, you can massage the lines without problem if you don't kink them.
They claim it swells some types of rubber. I wish I knew that before I spent the extreme $$$$$ cause I prefer Dot 5 .
Mac
Mac
I ain't buying that claim that it swells some rubber. Do they have any proof?
DOT 5 fluid was developed for the military in the '30's-'40's. At that time, it was noted that the DOT 5 would swell some rubber components in brake systems. It was further noted that all rubber brakes parts manufactured in the last 60 years or so are completely compatible with DOT 5 and do not swell or unduly deteriorate due to contact with DOT 5.
This paperbook information is found in this rather lengthy article. Pay attention to paragraph 6.11.
There's many, many references articles in the bibliography at the bottom of the article that will keep you off the streets for hours.
PS. One of the references was regarding the US Army procedure for changing military vehicles from glycol based fluid to silicone. It was stated to use the silicone fluid to push the glycol out of the system with a pressure bleeder. Further, a warning not to use chemicals or solvents to flush the system.
Jimmy needs to know more so if you can go back and add a link to the article, I'd be grateful.
Wow. Well, both of those recommendations come as a surprise. They fly in the face of what I tell people and what I've done when doing the conversions.
Don't let the title throw you.
http://www.mossmotors.com/SiteGraphi...luid_long.html
As far as the information in the article and the information provided by looking in the credits, I'll let the reader here determine if they are credible or not. I believe the are.
absolutely no issues.
thanks
