hello
Old Apr 3, 2011 | 04:31 PM
vet85's Avatar
vet85
Default hello
is it hard to change trailing arms on a 66 vert thank u
Old Apr 3, 2011 | 05:02 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
It's not hard, just a little time consuming. You must removed shock, brake line, emergency brake cable, strut arm, half shaft from spindle, and rear spring. You need to jack up the rear spring to remove tension on spring bolt and be sure to chain the spring up before removing the jack. There's a lot of downward pressure on the spring. Once you have everything loose from the arm, remove the trailing arm bolt and be careful to watch how many shims there are and which side they are from. They need to go back the same way.
Old Apr 3, 2011 | 05:21 PM
vet85's Avatar
vet85
thank u very much
Old Apr 3, 2011 | 05:23 PM
John 66 Vette's Avatar
John 66 Vette
I call myself a backyard mechanic. It wasn't hard to do. If needed I would do it again.
Old Apr 3, 2011 | 05:42 PM
Hitch's Avatar
Hitch
Its not all that difficult as described above unless the bolt is seized in the front bushing. Heck the last one I did was in Hampton Inn parking lot!
Old Apr 3, 2011 | 07:35 PM
PBChase's Avatar
PBChase
Reference the chassis service manual for your year car. I did the same on my 67 coupe and while it takes a little time, everything came out great.
Good luck!
To hello
