61 Instrument cluster removal
Old 04-07-2011, 05:48 PM
balusik
balusik's Avatar
Default 61 Instrument cluster removal
I want to paint my instrument cluster. Can i remove it without removing the dash pad?
-Mike
Old 04-07-2011, 05:49 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,084 Likes on 4,737 Posts
Army
Its the only way to do it !
Old 04-07-2011, 06:01 PM
firstgear
Support Corvetteforum!
firstgear's Avatar
2019 Corvette of the Year Winner
St. Jude Donor '15
the easiest way is to take out the seat and open the soft top lid. That way you can lay down on the floor with your feet (socks only) up on top of the soft top shelf. Looking straight up you should see a semi circle of nuts that hold the instrument cluster to the dash. You need to take all of them off.
Sorry, this is the best photo I can find, but at the top you can see the ledge that the cluster sits on and there is a series of holes on this ledge or shelf that the studs poke through for the nuts and washers.
It isnt a very comfortable position to work especially if you are tall and weight challenged.....
Old 04-07-2011, 06:11 PM
Frankie the Fink
Army
This shot is slightly close up than Herb's -- the white spots along the 'ledge' are the 5 bolts that hold the cluster to the dash...one of the bolts is quite difficult to get to let alone see. My car was missing that bolt and I didn't even try to replace it.
Old 04-07-2011, 06:55 PM
mike coletta
mike coletta's Avatar
Received 1,067 Likes on 513 Posts
Herb and Frank are both correct!!! I sure am glad that somebody takes pictures of all of this crap!!! Good job!!
Mike Coletta
Old 04-07-2011, 07:03 PM
balusik
balusik's Avatar
YOU GUYS ROCK!!! PICS AND EVERYTHING!!
-Mike
To 61 Instrument cluster removal
Quick Reply: 61 Instrument cluster removal
