I need help clock removal
Old Apr 11, 2011 | 12:51 PM
Tom Schaefer's Avatar
Tom Schaefer
Default I need help clock removal
Hi wondering if someone could help me with the removal of my clock on my 66I got everything off but 2 wires that feel spring loaded afraid to pull to much ,thanks Tom
Old Apr 11, 2011 | 01:02 PM
DZVette's Avatar
DZVette
Tom
If it's like the clock in my 65, the connections are shown in the attached PDF file. Connector might need some tugging. Hopefully it has not been rewired in some fashion.
Dave Z
File Type: pdf
Old Apr 11, 2011 | 01:07 PM
bluzrocker's Avatar
bluzrocker
Tom,
I just did a clock in-and out quartz conversion on my 67...yes there are 2 wires with the light bulbs attached to them at the back of the clock ..they are a push in -pull out set up...and 2 ea spring loaded u type spring loaded things that secure the clock in place and a single clip on (at the 6 Oclock position)light w/ a green shade on the bulb shield that clips on the clock housing.that illuminates your heater and radio controlls..I just simply removed the spring clips to let the entire clock come out and then pulled the 2 light bulbs and their sockets out ....I removed the clock clips from under neith but when i reinstalled I did have my glove box out and it was a snap that way
Bluzrocker
Old Apr 11, 2011 | 01:26 PM
Tom Schaefer
thank you Dave got them
Old Apr 11, 2011 | 01:27 PM
Tom Schaefer
Thanks bluzrocker I got them with your help
Old Apr 11, 2011 | 01:29 PM
Astrojet's Avatar
Astrojet
Hi
It's easy, and fast to remove a clock. Just use a claw hammer and pry on the clock and dash as hard as you can...........
No seriously, follow this:
1. Remove a side panel from the console. I always remove the driver side.
2. Reach up behind the clock and feel around for 3 rectangular metal clips. These are actually spring steel clips that hold the clock in position on the dash.
3. Push and compress just a bit one each clip. Once it is compressed about 1/8 of an inch, it will slide sideways when you push on it and off the "leg" or "pin" of the clock housing. There are 3 clips you must remove.
4. Once all the clips are out, and hopefully in a safe place to find later on, pull the clock out of the dash towards the rear of the car. Once it's out a few inches, reach behind it and remove the bulb and socket from the clock.
To install the clock, reverse those steps. Make sure when you push on the clips when seating them on the legs of the clock housing, you hear a slight "click" or "pop." They have an indentation on them, and that needs to be seated firmly so they don't come off on their own.
I guarantee you, that removing a clock will give you a sore back from laying upside down between the driver seat and under the dash with your back across the door sill plate, you will get 3 scratches on your hand that you use to remove the clips, and you will bump your head twice on the steering wheel.
Mike
Old Apr 11, 2011 | 01:33 PM
bluzrocker's Avatar
bluzrocker
never had any situations develope bad.......
when I disconnected the battery before doing anything under the dash.
Bluzrocker
Old Apr 11, 2011 | 01:47 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Originally Posted by Astrojet
Hi
Mike
Once you have done it a few times,all you have to do is feel around back there. No need to get contorted.
To I need help clock removal
