ignition switch.
Old Apr 23, 2011 | 03:34 PM
jmschmit's Avatar
jmschmit
Default ignition switch.
Need help ..can anyone tell me how to replace the ignition switch on my 58 vette? It's been many years since I messed with this. When I turn key to lock, sometimes it doesn't want to unlock.Does it need to be replaced? Thanks...Bill.
Old Apr 23, 2011 | 06:08 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Its quite simple to replace the switch however the new switch will not include the locking central cylinder -- which may very well be your problem. I would remove and pull out the central part and put the key in and look for worn spots, burrs, etc. If you have to get a new central cylinder then you should also change trunk/glove box locks too to match your new key and ignition tumbler.
To remove:
1) Disconnect battery
2) With key in switch place a paper clip in the small hole visible on the face of the switch
3) Turn key to the left and the central cylinder should come right out.
4) Take the connector off the top of the switch behind the dash.
6) Remove the face bezel with needle nose pliers (carefully -- don't scratch paint).
7) Remove switch from behind the dash.
DUB's Avatar
DUB
If my memory serves me correctly. There is a very small hole near the stainless bezel opening where you insert your ignition key. Using the key and a paper clip. Insert the key where it goes.and also the paper clip in the small hole and turn the key to accessory position and it will allow the lock cylinder to be removed...and thus allow you to remove the bezel that is holding the ignition switch to your dash panel. Sometimes you might have to turn the key to accessory (left) and then insert the paper clip...and then turn it further. But either way...this is how you remove the lock cylinder so you can get the bezel off.
"DUB"
Old Apr 23, 2011 | 06:10 PM
Frankie the Fink
Army
No "Accessory" position on a C1 DUB...
Old Apr 23, 2011 | 07:00 PM
1snake's Avatar
1snake
Sounds more like worn tumblers than a bad switch.
Jim
Old Apr 23, 2011 | 08:48 PM
DUB's Avatar
DUB
Thanks for the info. I do not get a chance to work on many of the C1 Corvettes...so I ASSUMED that they did have an accessory position. I guess I will insert my foot in my mouth now and shut up. Sorry about the bad info.
"DUB"
Old Apr 23, 2011 | 09:02 PM
Frankie the Fink
Army
No problem..you had everything else correct. I DO wish my '61 did have an "ACC" position. Without it -- no listening to the radio with the motor off if you value your ignition coil...
Old Apr 23, 2011 | 10:30 PM
jmschmit's Avatar
jmschmit
Thanks guys this helps me a lot. Bill
Old Apr 24, 2011 | 09:16 AM
DUB's Avatar
DUB
Thanks,
So was I correct in the procedure in removing the lock cylinder from the ignition switch? Even though it does not have an "ACC" position. Like I mentioned..I do not get many In my shop...and am just curious.
"DUB"
Old Apr 24, 2011 | 09:35 AM
Frankie the Fink
Army
Yes. The "paper clip in the hole" and turning the key counter-clockwise does the trick in the C1s... Personally I always disconnect the battery prior to switch removal...might want to add that to your procedure. These old cars are NOT fused well and grounding battery voltage can result in exciting and anus-clenching fireworks and smoke displays...
There is a special tool to remove the ignition switch bezel but I have had good luck (and no paint scratches) by using that blue "quick release" tape to tape the jaws of needle nose pliers to the exact width of the notches in the bezel and CAREfully twisting the arrangement counter-clockwise.
Old Apr 24, 2011 | 10:08 AM
Steve59's Avatar
Steve59
My switch did the same thing last year. It got hung up and wouldn't turn at all, got jammed. I ended up having to put a screw driver in the key slot and twisting until the tumbler broke lose.
It's a pretty simple mechanism. What you will find is the tumbler has a rectangular keyway type metal piece that retracks when you insert the key, allowing you to turn the tumbler in the switch housing. These keyways wear, get loose and fail to retrack all the way and get jammed in the switch. All the parts are readily available and relatively cheap. Just make sure you get the proper shaped one for your year. Like the buttons on the Wonderbar radio, some ignition key slots are flat and some are curved. I can't remember which is which, but my 59 is flat.
Old Apr 24, 2011 | 11:06 AM
JohnZ's Avatar
JohnZ
It's easier if you first insert the key, turn it all the way to the left (counter-clockwise), THEN insert the paper clip in the hole to depress the spring-loaded plunger and continue turning the key to the left until the lock cylinder pops out.
To ignition switch.
