Splined hub removal
Old 04-23-2011, 05:44 PM
saraholt61
saraholt61's Avatar
Default Splined hub removal
What are the correct size bolts that screw into the steering wheel hub enabling you to remove it off the splined steering shaft with a wheel puller.I have several bolts that came with my wheel puller but none fit.I hope the threads are not ruined.Thanks.
Old 04-23-2011, 05:55 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
I have always used a 5/16-18 bolt. I have not run across a steering hub from GM (in the early cars) that was different...but I could be incorrect...but I SWEAR it is a 5/16-18 bolt.
"DUB"
Old 04-23-2011, 06:24 PM
saraholt61
saraholt61's Avatar
"DUB"
Old 04-23-2011, 10:36 PM
Avispa
Avispa's Avatar
....of course you can always try the smash and pull technique. Get a thick 7/16 SAE (fine thread) nut, thicker than the part of the steering column that protrudes through the steering wheel hub. Pull the steering wheel toward you and pop the nut a couple of times with a 3# hammer. Worked for me every time.
To Splined hub removal
Quick Reply: Splined hub removal
