64 diff casting number help pleeze
Old Apr 30, 2011 | 05:25 PM
redvetracr's Avatar
redvetracr
Default 64 diff casting number help pleeze
can someone please post the correct housing and diff cover casting numbers for a 64 posi rear end? I have a diff stamped CB 2 (6, 7 or 3) then 64, the housing number ends in what looks like 763-N and the diff cover ends in what looks like 303, it also has a metal posi additive tag, the ring gear is stamped 3735390 11-37 GM 1 64 2 and yes it has an odd looking posi case (must be a Dana)...I believe it`s a 3:36 posi. thanks in advance.
Old Apr 30, 2011 | 09:06 PM
midstyle's Avatar
midstyle
'64 early 65 carriers cast 3818753-N; rear cover 3830303; your ring gear # is correct for 3.36 ratio '63-4; and your pinion gear would be 3819186. I'm not familiar with Dana posi cases, but you might see 32975 cast into the end of the case.. If it's 30117 it's a 1st design 3-series Eaton case.
Old May 1, 2011 | 01:41 PM
JohnZ's Avatar
JohnZ
Here's a photo (from Gary Ramadei) of a '63-'64 Dana Posi unit.
Old May 1, 2011 | 01:54 PM
redvetracr's Avatar
redvetracr
mine, thanks John
To 64 diff casting number help pleeze
