I have given up in my quest to get a Pertronix coil that will perfom and last.
I'm running the Pertronix Igniter III System.
The 0.3 ohm Blaster coil is the best for performance, being able to run to 6500 rpm and beyond, but I have been through 4 of them. None lasted more than 100 miles before the oil leaked out and/or secondary windings failing.
I tried the Pertronics epoxy 1.5 Ohm coil, but it will not allow the engine to rev past about 5800.
My backup coil is a NAPA replacement which I've had for several years. It is also limited to about 5800 rpm, but hasn't ever failed me.
The Igniter III is a multispark unit that seems to saturate lower performance coils at higher RPMs.
I'm looking for a high perfomance coil that will fit the original coil bracket and will not fail. Any suggestions out there?
A NAPA/Echlin IC12 coil has worked well in my GS for years. It's been good up to my self-imposed red line of 6500.
Jim
Jim, Are you running points/condenser or one of the electronic conversions?
I've had no problem with pionts/condenser/stock coil well past 6500. I installed the Igniter III due to the multi spark capability which helps my car in lower rpm drivablilty.
I went through two Pertronix coils while using my Ignitor I Pertronix unit. I ran the first coil without the ballast resistor in line as a call to the company said I could. It failed in a year and a half. Bought another and wired with the ballast in line. That one failed after one year. Good thing I always carried the NAPA replacement coil that I'd taken out. It saved me twice on the road and has been in place ever since the last Pertronix dumped. The Ignitor I is still going strong after 10 years and 25K miles but I'll never buy another one of their coils. Dave
My '69 Z/28 has its original Delco 480 distributor with Accel 28-32 oz. points, original 42-year-old Delco coil, and new stock plug wires, and revs happily to 7000 regularly; I've found no reason to use any aftermarket ignition stuff on it.
I recently installed the Ignitor III system and was contemplating acquiring their coil. I definitely won't waste my $'s after reading the above. The directions said to remove the ballast resistor but I decided not to. Does anyone know what good that would do?
it gives you full voltage to the coil when you remove the ballast
I've had both an Accel coil and Carquest coil fail on me.. I replaced the last one with a MSD Blaster coil and it has been there for a few years. Painted it black and called it a day. I think that the 6AL box was the cause of the failures.
Sure it's your coil?
I have blown 2 flamethrower coils.An oil and a solid. I gave up on them. It could be the Pert II doesn't use a ballast resistor. Maybe thats bad for the coil? But if that was the case? It would blow the GM coil too.
But I am able to get 6500 anytime with my Pert II ignition and my stock replacement coil.
Ps. For some reason, that setup also blew an Accel coil too. GM PURRS along.
You don't have to remove the ballast resistor but you should bypass it for the Ingitor III. This latest version is happiest with a full 12V.
I've run Pertronix equipment (including their coils) for decades under pretty brutal conditions with no problems in Mustangs, Chevy passenger cars and now my Corvette. Other old-timers on here (Tom Parsons) have similar good experiences. Most of the problems I've found with them when friends asked me to troubleshoot were improper installation or pinched wires or leaving the key in the ON position too long.
One item not mentioned is the choice of rotor. Most replacement rotors are the emissions design. The tang is about 1/8" shorter and will inhibit hi revs. Use an older Accel rotor w. the natural brass finish tang and matching cap. The newer Accel rotor s tang has a black finish and is the shortened design.
That wouldn't be true in my case. Or my GM coil would have gone the same way.
I think thats an internet myth. I get 6500 rpm from an over the counter oreillies BW cap.
I've been running the Mallory chrome high output coil for many years with no problems. If you go to the Summit Racing catalog, you will find that Mallory makes these for various types of ignition systems, and each will state what type of system it should be run on.
For example part 29219 states: "Designed for Mallory Unilite and Magnetic Breakerless distributors and conversion kits. Not compatible with aftermarket high energy inductive or capacitive discharge ignition systems."
