Pushrods
Old Jun 28, 2011 | 06:35 PM
TX63CONV's Avatar
TX63CONV
Default Pushrods
What are the pushrod specs for a stock 327 L76 build?
Old Jun 28, 2011 | 06:40 PM
Dave Tracy's Avatar
Dave Tracy
What specifications? Isn't the geometry for all small blocks the same? If you are running solid lifters, you would want to use the hardened rockers.
Old Jun 28, 2011 | 08:42 PM
65tripleblack's Avatar
65tripleblack
Stock length is 7.800 inches.
Old Jun 28, 2011 | 08:49 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Pushrods for SBC's can be bought in a variety of lengths depending on what has been done to the block, cam, heads, valves, etc. This is so you can get the contact patch between the rocker arm tip and the top of the valve correct. If the engine you intend to put them in is not modified with a decked block, shaved heads, etc. then the stock pushrod length should be just fine.
Is this the info you're after?
Old Jun 28, 2011 | 09:09 PM
65tripleblack
This is the pattern that you are after:
Old Jun 28, 2011 | 10:06 PM
wolfman64's Avatar
wolfman64
2020 C1 of the Year Finalist - Modified
Derek,
I still have the push rods from the engine for the 461 heads that I sold you. If you want them I'll bring them to Dallas with me the next time I come up.
Paul
Old Jun 29, 2011 | 03:46 PM
TX63CONV's Avatar
TX63CONV
Thanks Paul! I’ll take ‘em.
I found a nice set of comp cams pushrods laying around my friend’s shop but they are 7.30 and I wasn’t positive on the length. Thanks everyone!
Old Jun 29, 2011 | 04:29 PM
MikeM's Avatar
MikeM
Hey Joe! If ya' keep the hood shut, you don't have to guess what the right length is!
Old Jun 29, 2011 | 05:03 PM
MikeM's Avatar
MikeM
Old Jun 29, 2011 | 06:47 PM
dynocar's Avatar
dynocar
The above is good, important info, if push rod length is incorrect, premature valve guide wear and not getting maximum valve lift is some of the results, especially with high RPM engines and high lift cams. A little off subject but way back when we were setting up high RPM Ford 351Cs with high lift cams and very strong valve springs, we had to many valve guide issues. We solved the problem by off setting the rocker/to valve tip pattern because the second half of the cam lift was doing all the damage due to that being the most stressful portion of the lift. We put that portion of the pattern closer to center.
Old Jun 29, 2011 | 09:12 PM
wolfman64's Avatar
wolfman64
Derek,
Two things:
1) The push rods I have are 7.80". Is this the size you want?
2) I won't be coming to Dallas for about another month. I can put them into a USPS Small Flat Rate box and send them to you.
Let me know.
Paul
Old Jun 30, 2011 | 01:06 PM
65tripleblack
I see two shlt eatin' grins, so I know yer' kiddin' with me. I mustv'e taken an extra stupid pill today because your humor was completely lost on me.
Please enlighten.
PS: Nice engine perf at Englishtown (Raceway Park) last night.
Wish you were here.
To Pushrods
