Magnetic Oil Drain Plug Recommendation
Old Jul 2, 2011 | 03:43 PM
jtranger's Avatar
jtranger
Default Magnetic Oil Drain Plug Recommendation
I put magnetic drains plugs on my '61 & '65. I have tried the neoprene and copper gasket and oil still seeps from the plug. Anyone have a gasket that seals and where to get one? Thanks. Happy 4th
Old Jul 2, 2011 | 04:41 PM
sixtysixtom's Avatar
sixtysixtom
I use a copper ring with a rubber inner ring attached, works fine, no drips. I bought it a local parts store.
Old Jul 4, 2011 | 01:15 AM
babbah's Avatar
babbah
Old Jul 4, 2011 | 02:45 AM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Originally Posted by babbah
These are great and they can be re-used.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
Old Jul 4, 2011 | 02:16 PM
jtranger's Avatar
jtranger
Thanks Guys! We'll give it a try.
Old Jul 5, 2011 | 03:05 PM
spurline's Avatar
spurline
4th Gear
You can try www.goldplug.com
I know they have lots of different sizes.
Old Jul 5, 2011 | 08:59 PM
92GTA's Avatar
92GTA
That's what CC sent me when I ordered the gasket for my rear diff plug, now I know what the heck it's for
Old Jul 5, 2011 | 09:42 PM
MiguelsC2's Avatar
MiguelsC2
I bought a new garden hose that had an O ring instead of the familiar flat rubber washer.
That O-ring was a perfect fit to my rear diff plug. Looks like it belongs and dry as a bone.
Old Jul 6, 2011 | 11:17 PM
JBACE's Avatar
JBACE
CAUTION: All rubbers are not alike. Polymers and formulations vary greatly depending on the environment for which they are intended. It is likely that the hose o-ring is EPDM, whereas NBR would be preferred for the rear diff. It may look OK at installation, but over time it may deteriorate and leak.
Old Jul 7, 2011 | 12:50 AM
MiguelsC2's Avatar
MiguelsC2
If it comes to that? I will search out one formulated for oil usage. My C2 is inspected often. I will correct if it becomes a problem.
Even when no seal or o-ring is used. It only gets slight seepage.
My point was to suggest a large O-ring.
To Magnetic Oil Drain Plug Recommendation
