'62 Speedometer Problem
Old Jul 6, 2011 | 02:07 AM
Uncle Ralphy's Avatar
Uncle Ralphy
Default '62 Speedometer Problem
When driving, my speedometer bounces constantly from +/-20 to 90. And the odometer stopped working. Is this the speedcup & spring?
Old Jul 6, 2011 | 02:24 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Have speedo completely rebuilt and replace cable.
Doug
Old Jul 6, 2011 | 07:03 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I would examine the cable for damage first and replace it if need be -- if the old cable looks good then try lubing the cable liberally and then if no joy send the speedo out. A dry cable can bind and cause a jumping needle. You can chuck the tranny end up to a variable speed drill and simulate driving to test the cable.
HOWever the fact your odometer quit makes me think you are in for a head unit repair as Doug suggests...get the tach checked out and calibrated at the same time and save yourself add'l grief.
Old Jul 6, 2011 | 07:27 AM
toms silver 60's Avatar
toms silver 60
Bet whenever this is over, you'll wish it happened with the 57 instead of the 62!
Old Jul 6, 2011 | 09:21 AM
VetteJohn's Avatar
VetteJohn
Default Similar problem
I have just about the same thing happen right after I got my '62. The speedo would jump around and every once in while it would make noise like a siren. Before spending a BUNCH of money on the speedometer rebuild I replaced the entire cable. I pulled the cable out and it looked OK and I tried lubing it but it behaved the same. I examined the outside casing of the cable and it had a couple of "bad" spots so I replaced it. Problem gone!
Old Jul 6, 2011 | 10:57 AM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
My original is starting to jump around as well. What is the correct length for a 62 with the 3-speed trans? Any NOS out there?
Old Jul 7, 2011 | 08:23 PM
Uncle Ralphy
Frankie, I think you're right. I replaced the cable unit about 150 miles ago because the outside of the old cable had a burnt spot on it (don't remember how that came to be). The speedo had been jumping around a bit at that time, but nothing like now. Only a 20 mph variation from time to time, but the odometer worked.
I guess it's cluster removal time now. Actually, I had to replace the tach last year about this time, so I'm well versed in that procedure. This time I might remove the steering wheel as I put a little nick in my steering wheel hub last time and don't want to do that again, even after trying to keep it covered etc!
The '57 has a rebuilt speedo & cable so it should be good to go for some time.
Old Jul 7, 2011 | 08:44 PM
Frankie the Fink
Army
Yeah - removing the steering wheel isn't that tough and saves you some headaches...
Its still a PITA job on these cars.... I get a pillow and put a towel on the deck lid and just go inverted under the dash and lay my feet on the towel... The wife swears that's how she' gonna
have me buried in the car.
Old May 4, 2014 | 12:50 PM
my62toy's Avatar
my62toy
On my road trip from CO to AZ this week my speedometer started to "scream" at the head unit. I already had an intermittent odometer (for years) but the speedo worked. For now I disconnected the speedo cable at the transmission.
OK. it's time to rebuild the head unit. Has anyone documented a "step by step" procedure for removing the speedo? Last time I had the dash apart I scratched the outside casing. Don't want to do that again! Thanks in advance. Hal
Old May 5, 2014 | 07:45 AM
plaidside's Avatar
plaidside
I wrote an article on this a while back. PM me and I will send you a copy.
Joe
Old Jul 30, 2016 | 09:17 AM
elpasorabo's Avatar
elpasorabo
Default Article
Joe
You mentioned you wrote an article on pulling the speedo on a 62. I think my cable broke so I was going to pull it and have the speedo calibrated while I changed things out.
Old Jul 30, 2016 | 11:14 AM
plaidside's Avatar
plaidside
If you want a copy sent me your email address.
Joe
Old Jul 30, 2016 | 04:00 PM
elpasorabo's Avatar
elpasorabo
rbowen8@comcast.net
Old Jul 31, 2016 | 05:02 PM
plaidside's Avatar
plaidside
It is on its way.
Joe
Old Jul 2, 2018 | 07:40 PM
Ready2rRun's Avatar
Ready2rRun
8th Gear
Default 61 Speedo Noise and calibration
It is on its way.
Joe
hi Joe
i am a new 61 owner and my speedo has just started jumping around and a metallic whirring sound has appeared from behind the dash. I suspect I may have to repair or replace the speedo cable but there is nothing about this in the Corvette Service Guide so was hoping you could email me your step by step guide mentioned above.
Cheers Mark
Old Jul 2, 2018 | 07:41 PM
Ready2rRun's Avatar
Ready2rRun
8th Gear
It is on its way.
Joe
hi Joe
Cheers Mark
mlowe@bsa.com.au
Old Jul 3, 2018 | 08:06 AM
plaidside's Avatar
plaidside
Default Article
Originally Posted by Ready2rRun
hi Joe
Cheers Markmlowe@bsa.com.au
It is on it's way.
Joe
To '62 Speedometer Problem
Old Jul 3, 2018 | 08:08 AM
plaidside's Avatar
plaidside
Default Cluster
Article sent.
Joe
Old Jul 3, 2018 | 08:23 AM
Frankie the Fink
Army
Have the tachometer checked at the same time for health/accuracy.....those big cable driven instruments are the failure points on these cars....the "small" gauges are usually bulletproof.
Old Jul 3, 2018 | 10:11 AM
Dreaming60’s's Avatar
Dreaming60’s
C1 of Year Finalist (appearance mods) 2019
Mine worked perfectly (for the 150 miles I'd driven it) and then had the transmission speedometer gear changed out so it was accurate and shop just told me it's hanging up at 40 mph and then jumping to the correct speed. Does this sound more like a cable problem, rather than the speedometer head. Their suggestion, they pull the head and send it out to be rebuilt......which I'll do if needed.
Wow Frankie!! Your suggestion about the pillow and towel are fantastic! I can't get under my panel, as I can't contort my body in between the seat and the front door frame, so your suggestion might work for me. I'd like to be able to do this kind of work myself instead of farming it out.
Thank you!
BH
