61 braided strap engine compartment
Old Jul 13, 2011 | 01:24 PM
jtiernan's Avatar
jtiernan
Cruising
Default 61 braided strap engine compartment
There is a strap attached by a sloted screw on bottom right side of engine just below generator. It's about 6" long. Appears nothing is available for it to attach to. Does anyone know the use of the strap? Joe
Old Jul 13, 2011 | 04:37 PM
wib1961's Avatar
wib1961
It's one of the many ground straps for the car. It should attatch to the front engine mount I believe if I can recall correctly.
Old Jul 13, 2011 | 05:09 PM
oldsarge's Avatar
oldsarge
Lots of ground straps on Corvettes.
Old Jul 13, 2011 | 07:44 PM
chris ritchie's Avatar
chris ritchie
You can see the grounding straps for your car in the AIM. Look in the electrical section. From your description, it sounds like the strap on the motor mount. There should be one on each side.
Old Jul 13, 2011 | 08:42 PM
62Jeff's Avatar
62Jeff
I'm not familiar with a strap and a slotted screw over there, but here's the main ground strap at the passenger motor mount.
And here's both straps on the motor mounts
Old Jul 14, 2011 | 09:06 AM
jtiernan's Avatar
jtiernan
Cruising
Default 61 ground strap motor mount
Thanks for the picture and info. The AIM doesn't show the ground strap in question. What is the lower end of the ground strap attached to? The picture doesn't quite show this. It looks like the frame. Thanks again. Joe
Old Jul 14, 2011 | 09:41 AM
INMYBLOOD's Avatar
INMYBLOOD
From: The problem is all inside your head she said to me.
Jeff changing a water pump?
Old Jul 14, 2011 | 08:36 PM
62Jeff's Avatar
62Jeff
At the time I was, 3 year old picture.
Old Jul 14, 2011 | 08:37 PM
62Jeff's Avatar
62Jeff
The bottom end is connected to one of the bolts that holds the motor mount to the frame.
Check the Radio section of your AIM, that's probably where the ground strap is shown.
Old Jul 15, 2011 | 07:01 AM
chris ritchie
Look in the options section at the back of the AIM. Under "Radio - Ground Straps."
The lower end of the strap attaches to one of the bolts that hold the mount bracket to the frame.
Old Jul 15, 2011 | 09:04 AM
INMYBLOOD's Avatar
INMYBLOOD
Yes I figured it was an old pic.
Old Jul 15, 2011 | 01:48 PM
wilbur's Avatar
wilbur
I don't have that ground strap on my 58, should I? My car didn't come with a radio.
Old Jul 16, 2011 | 09:09 PM
JohnZ's Avatar
JohnZ
There are no slotted screws on the engine in a '61 Corvette (except the coil clamp and water pump rear cover). Sounds like a Bubba addition.
Old Jul 17, 2011 | 09:56 AM
jtiernan's Avatar
jtiernan
Cruising
Yea...that what I thought about the slotted screw. Looks like the strap should attach to the motor mount...both bottom and top of ground strap. Thanks. Joe
Old Jul 17, 2011 | 09:58 AM
62Jeff's Avatar
62Jeff
Joe if you don't have an assembly manual, or need a better picture of the other end of that ground strap, let me know and I'll go take a picture of my 62 and post it for you.
Old Jul 17, 2011 | 10:28 AM
jtiernan's Avatar
jtiernan
Cruising
Default Slotted screw
Thanks. I think I know where it goes now. The previous blogger sent me a picture with an explantion. The strap is bound at both ends to the motor mount bolts. If this is not the case let me know. Joe
Old Jul 17, 2011 | 10:33 AM
62Jeff's Avatar
62Jeff
Correct. Big connector goes over the large motor mount bolt on top of the orange mount that is connected to the block, as shown in my original picture. Small connector goes on a bolt on the black mount that is connected to the frame.
Old Jul 17, 2011 | 08:13 PM
jtiernan's Avatar
jtiernan
Cruising
Default Motor mount bolt
The bolt in the picture shows the nut on top of the mount. My bolt has the nut on the bottom of the mount. Which is correct? If nut goes on top, is it hard to get the bolt out once it is in the mount? Like I said, this guy detailed my engine compartment by taking engine out of car. Thanks. Joe
Old Jul 17, 2011 | 08:20 PM
62Jeff's Avatar
62Jeff
The nut goes on top, and it is not normally difficult to remove the bolt.
To 61 braided strap engine compartment
