collapsable steering column
Old Jul 23, 2011 | 04:22 PM
vt65's Avatar
vt65
Default collapsable steering column
does anyone make a collapsable steering column for a 65 Vette? Is it even possible to get one to fit as i cut 1&1/2 in off my stock column to install a Borgeson box....seemed like the thing to do at the time ..
Old Jul 23, 2011 | 04:56 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i believe Ididit and Flaming River make collaspible columns.
Bill
Old Jul 24, 2011 | 03:49 AM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Are you talking collapsible safety column or a telescopic?
The ones above are tilts.
Did you cut the mast jacket and the shaft or just the shaft?
In either case, the shaft and coulmn (mast jacket) wll be exchanged with any new coulmn.
Or just replace with a stock replacement shaft. $100
Old Jul 24, 2011 | 07:09 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
this might work in a C2
http://www.ididitinc.com/universal_s...ns/adj_col.htm
or here are collapsible shafts
http://www.flamingriver.com/index.ph...ts/c0008/s0001
they are COLLAPSIBLE, not telescoping.
Bill
Old Jul 24, 2011 | 10:42 AM
vt65's Avatar
vt65
I cut the shaft only, was thinking collapsable but why not get a T&T also, thanks for the
links ....
Old Aug 19, 2014 | 08:36 PM
Nitrous 74's Avatar
Nitrous 74
Part way through the Borgeson conversion on my 66 and considering this myself. I'm not sure that the ididit or flaming river columns are collapsible. Anyone figured out a good way to upgrade to collapsible steering column in a pre 67 C2?
Old Aug 20, 2014 | 09:57 PM
Nitrous 74's Avatar
Nitrous 74
Going to Carlisle this weekend. If I find a 67 Column would that bolt right in? Thinking this may not be cheap though!
Old Aug 21, 2014 | 03:30 PM
JohnZ's Avatar
JohnZ
'67 columns in usable condition are very expensive, and you also need the '67 pedal support and '67 intermediate mounting bracket to attach it properly in the car.
Old Aug 26, 2014 | 10:57 PM
Nitrous 74's Avatar
Nitrous 74
JohnZ, after some time in the Carlisle swap meet I can certainly say you are right, and also not the easiest conversion looking at the parts.
Stock 66 column it is for me!
To collapsable steering column
