Casting date on a 3 speed transmission
Old 09-09-2011, 02:44 PM
MOXIE62
MOXIE62's Avatar
Default Casting date on a 3 speed transmission
The casting number appears to be 3748868 and the date looks like 1201. This is in a 62 vett. Can some one give me the correct casting number for a 3 speed (if what I show is wrong) and what is 1201, thanks
Old 09-09-2011, 02:48 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,859 Likes on 1,102 Posts
That casting number is actually 3743368. The casting date is I 20 1, which is September 20, 1961.
Old 09-09-2011, 03:19 PM
MOXIE62
MOXIE62's Avatar
Default IS transmission correct for a 62
Could a transmisssion with a 61 Sept date be correct for a 62 car made the first week of March, 1962
Old 09-10-2011, 01:07 AM
UberLegend
UberLegend's Avatar
Old 09-10-2011, 01:54 PM
JohnZ
JohnZ's Avatar
Technically, yes, since it's inside the six-month window; however, transmission numbers aren't judged (except in Star/Bowtie judging). That time span certainly isn't "typical", but it's possible. The actual transmission assembly date is stamped on the machined rear face of the main case on the passenger side, between the two tailhousing-to-main case attaching bolts.
Old 09-10-2011, 03:41 PM
MOXIE62
MOXIE62's Avatar
I found the numbers you were talking about, I think. The number I found was stamped on the back of the middle portion of the transmission and on the machine surface and from what I could tell looking up at them from underneath, they were S9 29. Does that make any sense to anyone..
Old 09-10-2011, 10:09 PM
Dan Hampton
Dan Hampton's Avatar
Received 1,781 Likes on 830 Posts
2018 C1 of Year Finalist
Not a high demand transmission in '62. Only 12% came with the 3-speed. The lag is entirely possible. Very weak 2/3 synchro.
Old 09-11-2011, 01:12 PM
JohnZ
JohnZ's Avatar
Yes, that says the transmission was assembled at Saginaw on September 29, and the 9 days earlier casting date says it was in 1961.
Old 09-11-2011, 08:51 PM
Dave K.
Dave K.'s Avatar
Help me understand this dating. How does the 9 days earlier say is was made in '61?
Old 09-12-2011, 01:08 PM
JohnZ
JohnZ's Avatar
To Casting date on a 3 speed transmission
Quick Reply: Casting date on a 3 speed transmission
